Long Crank Times
Old Aug 17, 2010 | 06:18 AM
84FB351's Avatar
84FB351
Long Crank Times
I recently bought a 2002 7.3 truck. it has 90,000 on it and i love it. I was hoping you guys might shed some light on a long crank time symptom though. During a cold engine start up it will crank normally and fire right up, but if i run it to operating temp it will have an extended crank time to fire up (~6 seconds or so) it is noticeably longer than a "cold start". This seems abnormal to me. What are your thoughts?
Old Aug 17, 2010 | 10:02 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Hard to say without hearing it, but our trucks can have varying start times because of the high pressure oil system that it uses. More than likely you are par for the course and are experiencing the same thing we all do.
Old Aug 17, 2010 | 10:46 AM
jwhitetail's Avatar
jwhitetail
Normal, after it's warmed up it will crank a few seconds longer than when its cold. That's just the way it goes.
Old Aug 17, 2010 | 10:57 AM
clintbonnie's Avatar
clintbonnie
But 6 seconds..? that is too much.. Just for fun, I would check the level of the oil in your High Pressure Oil Pump (HPOP) after the engine is up to temp.. should be about 3/4" from the top .. Does it takes 6 seconds if you shut it off and quickly re-start?
Old Aug 17, 2010 | 11:03 AM
superduty4x4's Avatar
superduty4x4
Dirty IPR...
Old Aug 18, 2010 | 12:05 PM
84FB351's Avatar
84FB351
If i shut it off and restart right away it starts quick and acts normal.
Dirty IPR? what is this?
Old Aug 18, 2010 | 12:19 PM
superduty4x4
IPR= injection pressure regulator. Its located in the HPOP (high pressure oil pump). There are a bunch of threads here on how to remove/clean it.
F33lmywrath
Sep 18, 2016 09:42 AM
bradley brinegar
17
Aug 3, 2015 06:02 PM
fredws
Modular V10 (6.8l)
Jan 27, 2014 12:46 AM
Sonny Dee
15
Sep 21, 2011 05:19 PM
villestrip
Apr 30, 2011 08:50 AM
