one more question stacks
Old Aug 16, 2010 | 08:12 PM
94 smokin stroker's Avatar
94 smokin stroker
i have a friend who his family owns a grading hauling towing company and they have 45 big rigs 4 are 80 ton wreckers and he said they bought a brand new 6 inch stack for a truck and didint use it and will sell it to me for 75 bucks my question is will a stack make my truck sound more like a deep rumble diesel or gasser 460 sound and how do you guys think a single 6in stack in the middle of the bed would look thnks
Old Aug 16, 2010 | 08:27 PM
Coalroller's Avatar
Coalroller
im not a big fan of the single stacks...maybe in a dodge bed but thats about it oh yeah itll be deep and rumble trust me i have two 7s and wow you can hear the turbo alot more too!
Old Aug 16, 2010 | 08:32 PM
Coalroller's Avatar
Coalroller
sorry i should have said tho the 6" will sound good either way, whether you just the one or go with 2!
Old Aug 16, 2010 | 08:39 PM
megawatt00's Avatar
megawatt00
Thee only problem with that Adam is fitment. It will sound killer. But you will have to buy adaptors hangers elbows all that stuff to do it right. You may be better off with a tried and true kit.
Old Aug 16, 2010 | 08:55 PM
94 smokin stroker
Well thats what i thought the trouble might be. Thanks for the help guys i will keep you posted on the decision.
Old Aug 17, 2010 | 01:05 AM
rupejosh's Avatar
rupejosh
if you put it in the middle its a pain to use your rear view,when i had mine i had it at the pass.side of the bed all i did was take a piece of plate steel cut a hole the same size as the factory pipe in the middle and welded a piece of the factory pipe to the hole and then found a piece of pipe that fit inside the stack and welded that on top to reinforce the stack then slid the stack over it and welded it on.then cut a hole in the bed same size as factory pipe then slid the adapter plate i made through it and bolted it to the bed,then used flex-pipe to connect the exhaust because of all the flex these trucks have.i didnt want to be re-welding exhaust all the time.
73plymouth
Exhaust Systems
Mar 29, 2013 10:07 AM
jg96powerstroker
Sep 16, 2010 10:36 AM
Storm
30
Oct 1, 2007 09:14 AM
69cruiser
15
Jun 19, 2005 06:22 AM
seanm
Mar 30, 2004 07:10 PM
