instructions to open PCM box
Old Aug 16, 2010 | 06:59 PM
MHK's Avatar
MHK
Smile instructions to open PCM box
Does anyone know how to open the PCM medal box to get to the printed circuit?
I took all the screws out, so there must be a trick to it.
2004 F150 XLT
Reg Cab Flareside
4X4 5.4
Old Aug 16, 2010 | 07:27 PM
bridge's Avatar
bridge
Sick 'n Tired
"This is highly irregular Dave"
Why do you want to get to the printed circuits? I feel I must ask prior to helping you get it open.
"noli tangere PCM"
Old Aug 17, 2010 | 08:55 AM
MHK's Avatar
MHK
Smile
I want to probe it with the multimeter to see why the 4x4 module is non responsive.
Old Aug 17, 2010 | 11:33 AM
EBTDM's Avatar
EBTDM
"noli tangere PCM"
Now that's funny!
Old Aug 17, 2010 | 11:57 AM
MHK's Avatar
MHK
Smile
OK, I am slow today.
I am going to help you HAL.
Old Aug 17, 2010 | 05:02 PM
Oldguy4's Avatar
Oldguy4
Have you tried checking the plug on the transfer case motor? Guys have found corosion there. Also whacking the motor with a hammer has helped.
Old Aug 17, 2010 | 06:28 PM
bridge's Avatar
bridge
Sick 'n Tired
The PCM is what they call "none serviceable". Meaning, when one is suspected of being bad they remove it, chunk it and install a new one. So, there is no procedure in the service manual to open that puppy up. I'm guessing you'd have to break it (EEK! Moisture!) to get into it.
There are a host of diagnostic hints and tricks we could point you towards for solving your problem. However, if you're at the point of cracking the PCM I'm guessing you've exhausted all those other options!
Good Luck!
Old Aug 18, 2010 | 04:53 AM
svt2205's Avatar
svt2205
I would expect the boards inside the aluminum PCM case to be 100% encapsulated to prevent environmental conditions from effecting the boards or components. It's a common practice to protech this sort of electronics. That said, you can often bake the board at controlled temps/times to soften the RTV up so you can access portions of the board. But you had better have the drawings showing you where you need to go vs trying to access the entire board. (one of my past lives was at an aerospace electronics manufacturer and we would need to rework parts from time to time, not fun)
So even if you open it up, it's very unlikely you will be able to see the boards and components to check things out. Plus, you're going to make it so the dealer wont accept the PCM as a core (do they still do this???) when/if you need to replace it.
Things are non-servicable for a reason, it's not just so they can sell you an expensive new assembly.
Old Aug 18, 2010 | 12:16 PM
MHK's Avatar
MHK
Smile
I need to speak with a rebuilder or remanufacturer to gain this knowledge.<!-- google_ad_section_end -->
Old Mar 14, 2023 | 06:40 PM
Musclford's Avatar
Musclford
2nd Gear
Check out my post
https://www.f150forum.com/f4/crank-n...8/#post7390710
lazarus27
1997 - 2003 F150
Aug 16, 2015 09:26 PM
airboatoutlaw
1978 - 1996 Big Bronco
Mar 5, 2011 05:22 PM
Robsride
Jun 22, 2010 04:12 PM
1bigjoe
19
Feb 18, 2010 09:43 PM
Dwinn
Computer Chips & Tuners
Oct 7, 2005 10:01 PM
