351w brackets help
Old Aug 18, 2010 | 09:43 PM
wadar1969's Avatar
wadar1969
First, the 89 setup you have on your motor. Does the water pump turn clock wise and is it short or long nose, and is the alt a 2g or 3g. Did you get the water pump, alt, p/s pump and a/c comp. off the 89 donor motor. If it is what i need i may just look for an 89 f150 setup for mine cause i really like the way it looks and if it bolts right on then that a definite bonus.
Old Aug 18, 2010 | 10:00 PM
first today's Avatar
first today
According to the belt diagram on the 79 mustang routing, it goes counter clockwise while everything else goes clockwise. The part stores say it is a standard rotation water pump. I think it is a short nose. The 79 and 89 water pumps look identical, except for the rotation.
The 89 alternator was not a 3g. I am using a 3g on the motor though. It is in place on the engine in the picture.
I got it all from the 89. I am using the alternator bracket from my 79 mustang though. The only reason is that the brackets are almost identical to the 89. I already notched the bracket for the 3g upgrade and am saving the 89 for a spare.
click on that picture of the engine and it will take you in to my flickr page. I have more pictures in there. You can see the grimy brackets on the 89 before I cleaned and painted them.
Old Aug 19, 2010 | 11:14 AM
loudfords's Avatar
loudfords
If the water pump goes counter clockwise, it is reverse rotation. Look at the back of the water pumps, the ports are angled different on standard and reverse rotations. Also, in my experience, the standard rot. pumps usually have a cast iron housing, while the reverse pumps usually have an aluminum housing.
Old Aug 19, 2010 | 03:21 PM
first today
I am going to go with the water pump for the 79 mustang 5.0.
The 79 is an identical outer shell of the 89 and 93 water pumps with reverse rotation. The 79 water pump jackets match the water jackets of my mechanical fuel pump timing cover. The 79 mustang has a factory serpentine belt system almost identical to the 89 F-150. The water pump is standard rotation, with an aluminum case for the 79 mustang 5.0. This is the part number and info from autozone:
Duralast New/Water Pump
For your 1979 Ford Mustang 5.0L 2BL 8cyl
Part Number:
CWP-572
Features & Benefits
Manufactured to meet OE specifications, the Duralast water pump features all new, original equipment-quality components for proper fit and long-life performance. Each includes Heavy-Duty unitized bearings, pressed-on hubs, precision machined housings, unitized seals and Optimal impeller clearance, plus all new water pumps are 100% factory tested to assure the highest quality product.
Part Number: CWP-572
Weight: 6.13 lbs
Warranty: Limited Lifetime
Notes: *** Extended life antifreeze is highly recommended with this aluminum pump. ***
Hub Height: N/A
Pump Rotation: Standard rotation - same as crankshaft
Special Installation Notes Included: No
Arm Configuration: No
Old Aug 19, 2010 | 03:25 PM
first today
This is the info for the 89 F-150 with fuel injection.
Features & Benefits
Manufactured to exceed OE specifications, the Duralast high performance water pump features all new, original equipment-quality components for proper fit and long-life performance. Each includes Heavy-Duty unitized bearings, durable ceramic seal faces, performance-tuned impellers, and zinc plated backplates. Aluminum tumble polished housings available in some applications. All new high performance water pumps are 100% factory tested to assure the highest quality product.
Part Number: CWP-657HDA
Weight: 8.0 lbs
Notes: Heavy duty aluminum pump, increased cooling capacity/heavy duty components. *** Extended life antifreeze is highly recommended with this aluminum pump.***
Pump Rotation: Reverse rotation - opposite of crankshaft
Old Aug 19, 2010 | 07:38 PM
first today
I have posted a thread in the general auto information area for help from any 79 mustang owners. This is it https://www.ford-trucks.com/forums/9...ce-please.html .
Loud fords, I do not disbelieve anything you have said. You have made valid points and I am trying to do my best to get my engine right. You have actually helped me a lot. I bought a reverse rotation pump awhile ago and had it bolted to my engine. Looking at it closer I now see why I can not run that pump with my timing cover. I really do not want an electric fuel pump since I already have a aftermarket mechanical one.
Old Aug 20, 2010 | 11:11 PM
first today
I have deleted this post. I went to an old friend today that has dealt with mustangs for the past 25 years.
Look at the above thread link in my above post for the solution.
7379ford
Feb 11, 2017 07:10 PM
Mr. Ed
Jul 4, 2016 09:27 AM
dsmit412
Jun 29, 2016 10:28 PM
BossFan
Aug 8, 2011 09:06 PM
nickmobile67
Aug 2, 2011 02:10 PM
