302-351 accessory brackets interchangable?
Old Dec 23, 2010 | 08:50 PM
nickmobile67's Avatar
nickmobile67
I'm going to a 351w from my 302. Will I be able to use the same ac compressor bracket, power steering pump and bracket, alternator bracket, ect? I think the heads, timin cover, and water pump are the same so I don't see why it would be a problem but I want to make sure. Thanks!
Old Dec 23, 2010 | 09:07 PM
BlueOvalRage's Avatar
BlueOvalRage
I can't say for certain without knowing exactly what year and model you're working on, but in most cases, yes, they are interchangeable. The only external difference between the motors geometrically is the deck height. That puts the heads about an inch farther away from the water pump. Some bracket assemblies (especially serpentine setups on the left side of the engine) bolt to both the head and the water pump. Ford accounted for this on most of them, though, and had two sets of water pump holes in the brackets for either engine.
Old Dec 23, 2010 | 10:03 PM
Conanski's Avatar
Conanski
The sets I have fit both motors so you should be good to go.
Old Dec 25, 2010 | 10:13 PM
34rdztr's Avatar
34rdztr
most truck brackets have both holes for 302/351 engines. if you are trying to use mustang(fox body) brackets,you wiill need a changeover bracket for it. eddie
Old Dec 30, 2010 | 05:45 PM
TheJunkMan's Avatar
TheJunkMan
I had to use my brackets from my 81 351w to my 89 5.0, and I had to do some modifications. Nothing too severe though. The alternator had to be shimmed around a bit, but the power steering bracket I had to add a hole and cut one of the corners off that was interfering with my after market waterpump. Also I had to add a chamfer to and flip the plate that was on my head that the long power steering pump bolt went into, so that the offset went the other direction due to the change in deck height. So it's definately do-able, but may require some redneck engineering.
Old Aug 2, 2011 | 02:10 PM
nickmobile67
FWIW my 302 brackets were too short for to fit my 351, I was able to weld tabs to the brackets to extend them out to the water pump though.
Branded
Ford Truck Parts for Sale
Jan 21, 2017 02:43 PM
Mr. Ed
Jul 4, 2016 09:27 AM
mismith
Mar 29, 2015 07:23 PM
danlee
40
Feb 20, 2012 06:59 PM
Ringo Fonebone
Aug 22, 2004 01:04 PM
