Ford power steering bracket help
Old Jun 28, 2016 | 06:53 PM
dsmit412's Avatar
dsmit412
Does anyone know if the power steering brackets are different on a 302 vs a 351w ? I have a 1980 F100 that used to have a 302 i switched it over to a 351w with aluminum heads now the power steering bracket does not fit any help would be much appreciated thanks.
Old Jun 28, 2016 | 07:38 PM
Franklin2's Avatar
Franklin2
The pulleys won't line up or the bracket won't bolt up? If the bracket has bolt holes in the block and the head, I can guarantee the holes won't line up, the 351w block is taller, that puts the heads up higher and further apart, even though the heads will fit a 302 block.
Old Jun 28, 2016 | 07:54 PM
dsmit412's Avatar
dsmit412
Yes the bracket will bolt up but then the power steering pump wont line up so do you think i just need to get 351w brackets ?
Old Jun 28, 2016 | 10:25 PM
Gary Lewis's Avatar
Gary Lewis
The brackets are different:
Old Jun 28, 2016 | 10:58 PM
Gary Lewis's Avatar
Gary Lewis
Also, I put up two new pages on my web site. Not sure they'll help you as I've already posted the answer to the question, but for future questions:
Old Jun 29, 2016 | 06:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E2BZ-3C511-A (replaced D8OZ-3C511-A) .. P/S Pump Support Bracket - Use with C-II P/S Pump / Obsolete
Gary, you didn't ask, but someone in the 1948/56 forum did, so I gave him EVERY applications for this puppy, as it was also used in...
1978/79 F100/150 and myriad 1978/82 passenger cars.
And btw, the 1980/89 truck parts catalog application is wrong as no F350 of any year came with the anemic 255 or the 302.
Old Jun 29, 2016 | 10:28 PM
Gary Lewis's Avatar
Gary Lewis
What!? The catalog is wrong? Sacrilege!
BossFan
Aug 8, 2011 09:06 PM
racer3022001
Engine Swaps
May 3, 2008 09:30 AM
Grumpy Gramps
Jul 20, 2005 11:36 PM
