04 Aviator A/C question
Old Aug 15, 2010 | 02:01 PM
1quikta's Avatar
1quikta
My wife's 2004 Aviator (80K miles) started making a rattling noise. I investigated and it is coming from the A/C compressor. It quits when the system is shut-off, but is rather noisy when on. It is seeming to get worse within the past few months. Is the compressor trashed? The A/C still works great and psi is normal. I looked up prices and they range around $375-$400 for the compressor. How many book hours to replace? I don't see myself doing that.
Thanks,
Chris
Old Aug 15, 2010 | 03:48 PM
steve(ill)'s Avatar
steve(ill)
when the system is "on" the clutch is locked up and the pulley is spinning with the compressor. YOu might have excess clearance (air gap) in the clutch plates, or nois could be internal. look at the clutch first, see the air gap- measure.
Old Aug 15, 2010 | 03:57 PM
Moto Mel's Avatar
Moto Mel
I've had this happen on a couple of the Fords I've owned and in my case, just the magnetic clutch, not the compressor itself. On your truck it is a little difficult to get to but otherwise an easy job. Just 1 allen or torx bolt after releasing the main belt but loosen the bolt first.
Check the link and you will see what it looks like.
Air Conditioning Clutch by Factory Air - Part 47878 - Advance Auto Parts
Old Aug 15, 2010 | 10:15 PM
1quikta's Avatar
1quikta
Thanks for the info guys. Is there any way to make sure it is the clutch only? It sure looks like a PITA to get to, but I think I can change out the clutch. Now with doing the clutch, does the A/C have to be serviced or is it separated?
Old Aug 16, 2010 | 04:31 AM
Moto Mel's Avatar
Moto Mel
Look at the pic in the link I sent to you, it's just 1 bolt and no other service should be needed. Your system should not leak at all and the noise will be gone.
Old Aug 16, 2010 | 10:51 AM
1quikta's Avatar
1quikta
Thank you sir, I will update this post when I try the clutch.
kountzecobra
Feb 22, 2016 08:38 AM
renchr56
1997 - 2003 F150
Oct 23, 2015 07:09 PM
oldfart1961
Aug 22, 2015 07:24 PM
R T
Jul 30, 2015 10:45 AM
mike L
Jun 2, 2015 06:29 PM
