bone yard 135a a/c compressor
Old Jun 2, 2015 | 04:08 PM
mike L's Avatar
mike L
An a/c compressor is $27.00 at the bone yard, with warranty. I noticed the top a/c tube is cut off and folded over. After about six month what happens inside the compressor when the air gets in? Is it worth buying used, if I do the work myself? I would have to buy the tools.
Old Jun 2, 2015 | 06:02 PM
justcruzin125's Avatar
justcruzin125
As long has no water got inside, you should be ok. You can pull the compressor apart to check internals for rust. Just careful how u pull apart as there is many small parts inside. Other than that a shot of PAG oil before adding refrigerant is all you need to get it functioning
Old Jun 2, 2015 | 06:29 PM
eakermeld's Avatar
eakermeld
Probably a better one than you can order new (cheap import crap!). I wouldn't take it apart though. The thing might not seal back up. I would, however, give it a good flushing with the best flush solvent you can find. Then put new oil in it (proper amount by the book), pull a good vacuum and make sure it holds, juice it up and see what happens!
rickfar
Escape & Escape Hybrid
Apr 15, 2011 09:18 AM
lupin398
Jun 27, 2010 07:54 AM
cantwait
Jun 10, 2010 03:53 PM
orve
Feb 28, 2009 01:44 PM
Novitsky
Sep 9, 2007 09:48 AM
