Considering a 6.9
He said he will take $1000 for it, "as is". I live in upstate NY and he in VA, about 500 miles I think. So there would be that expense as well. I need some advice.
Thanks
My bet would be glow plugs. Its also possible that a really slow starter could do it. These engines need a decent cranking speed to fire off.
To test the glow plug theory (assuming its not an 83-85.5 truck!) you can have the block heater plugged in for a few hours before you attempt to start it. Might also put the batteries on charge for good measure too. If the fuel system is still in decent condition, it should fire from that amount of heat alone. Crank with the pedal on the floor until it starts sputtering, then ease off. Give it only enough fuel to keep it running and don't blip the throttle or rev it really high to get it going. It will clear its throat on its own.
Also, replace the fuel filter (fill it with diesel first). Make note of any funny color of the fuel in the old filter as it could offer some clues as to what is going on.
If it does turn out to be glow plugs, first, check to see if they are beru/motorcraft. If not, you need to be veeeery careful when removing them if they are something like champoin or autolite. Tips can break off and fall into the engine causing all sorts of carnage. Use only beru glow plugs if you have to replace them.
Assuming whatever the problem is isn't serious, does a grand sound like a good price?
Thanks again for the help.
They *should* self prime simply by cranking and I've done it with mine on several occasions. Some other guys say theirs will not self prime no matter what and need to add fuel or (gasp) use some form of starting fluid to get it going again.
Some things to be aware of;
Crank for a maximum of 20 seconds at a time and allow a minimum of 2 minutes cool down for the starter (I tipically crank in 10 second bursts)
Starting fluid is something I never encourage using but if you must, disable the glow plugs first and use VERY short bursts.
If you suspect air in the lines, check the fuel filter as I mentioned earlier and verify that its full of fuel. If not fill it up and it will save you time, and the starter a few more years of service.
To verify that fuel is getting to the injectors, loosen a few of the injector lines at the injector end to see if bubbles or fuel is comming out. It should have a mild drip of steady fuel if the lines are getting fuel.
