Taps, 21 gun salute, E4OD laid to rest...
Old 08-15-2010, 09:47 AM
Groundpounder0331's Avatar
Groundpounder0331
Groundpounder0331 is offline
The local shop is doing the work for better or worse. The owner knew alot about E4OD's. About two months ago I was having shifting problems from 1st to 2nd gear, and he stated the VSS and CPS may be bad. I replaced the CPS and the shifting problem was fixed. He charged me nothing for the advise, a scan, and sent me down the road. I then put about 3K miles on my truck in one month towing my 9K RV all over the Cascade mountain passes, which is when I started having different different problems. Anyhow, I do appreciate the advice.
Old 08-15-2010, 10:33 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Sounds like you have a tranny guy that knows his stuff. Would be interesting hearing your impressions after the build.
Old 08-15-2010, 01:18 PM
EMD_DRIVER's Avatar
EMD_DRIVER
EMD_DRIVER is offline
Could you elaborate on the shifting problem you were having? My 1-2 shift went from quick and firm, to taking 3-4 seconds..
Thanks!
BenMitchell
08-19-2014 03:24 PM
hairyboxnoogle
02-11-2014 07:39 PM
nmhs
11-24-2013 07:04 PM
bvmbandit
08-15-2013 07:50 PM
bjmc621
01-15-2010 09:11 AM
Quick Reply: Taps, 21 gun salute, E4OD laid to rest...
