E40D build
Old Feb 9, 2014 | 07:58 PM
hairyboxnoogle's Avatar
hairyboxnoogle
E40D build
Ive never been on this particular board here so let me just say hi to start things off.
I picked up a 95 E40D from a stoker here a few weeks ago with the intent to build it and drop it in behind my IDI. To be on the safe side, im going to say i want the transmission to be able to handle 600bhp as a DD / tow rig. Ive read and heard alot about upgrading various parts in this transmission to get the all around best. What i havent read, is a parts list of such parts. To get the ball rolling i was going to pick up Suncoast's
ford-e4od-xtreme-duty-master-rebuild-kit/. To augment that i was looking at either the transgo-tugger/ or the e4od-transgo-pumpaccum-kit/. From there is where im in over my head. Things like billit inputs, drums, and dual load center supports. I was also looking at the 427-line-mod-valve/. I dont want chatter your teeth shifts, but when going 2-3 up a 6% grade grossing 25k i want it to shift, not half assed slip into gear. Beyond that, i could really use some advice on a torque converter.
Now on to part two. That is the plan for the trans in the long run, possibly even short run. However, im on a tight budget trying to throw parts together to get ready for a dyno weekend / get together, and i didnt factor in the cost of a transmission (was originally going to keep the ZF). The guy i got the trans from was 90% sure it was the TC that was bad, not the tranny, he just wanted an excuse to drop in a ZF. Tranny only has 152k on it, and if it checks out, i was thinking about doing the shift kit and converter just to get me to washington and back for the dyno day. So i guess my question is, under those circumstances, will the transmission be okay, or is failure eminent? Going to drop the trans off at Aamco sometime this month and have them see what they think.
Old Feb 9, 2014 | 08:00 PM
hairyboxnoogle
Oh, some relevant info i remembered, 4.10 gears, 285/75 tires and will probably eventually get an exhaust brake. Who do you guys recommend for a trans controller?
Old Feb 11, 2014 | 07:39 PM
the builder's Avatar
the builder
I have been building these converters for awhile the major flaws are the thrust washer under hub make sure you get a bearing under the hub also have a sonnax improved oil flow spline in the turbine helps improve the oil pressure keeping the clutch away from back cover also a billet back cover will be the best option
BadDogKuzz
108
May 12, 2020 10:27 PM
oldbird1965
189
Oct 31, 2012 09:23 PM
Powerstroke-7.3
31
Oct 22, 2012 09:01 AM
kupaa
Jun 4, 2010 04:23 PM
Boostcrazy99
Sep 2, 2008 10:05 AM
