Should I keep my 6.0?
thanks for the links, that helps. So since my truck already has 35k miles on it with stock coolant and no coolant filter, and thinking about the cost of the VC-9, coolant, water etc, it's not cheap to do, so should I consider replacing (or deleting) the EGR cooler since it may be a little too late due to the miles I already have on it? Is there anything else I should do at the same time to make it more reliable?
What are the pro's and cons of the EGR cooler delete as apposed to running a bulletproof EGR cooler? will I need to do the oil cooler as well? And finally, since in in CA will any of these mods affect the fact that I have to smog my diesel now? Thanks for all the advice everyone!
Do the flush yourself, my dealer botched it. Here's the course. Hope this link works.
Coolant Change 101 - Ford Truck Enthusiasts Forums
I am not one who believes you have to delete your EGR to have a reliable truck. I am also in CA, and I definitely won't be deleting mine.
I am in your shoes, Heckler. I drive mine about the same as you drive yours. Mine is now in the shop for head gaskets, but I was covered by a $2k extended warranty. I believe if you continue driving that truck the way you have been, it's not IF it'll blow the head gaskets, it'll be WHEN it'll do it.
My recommendation is to replace your EGR valve and oil cooler with an aftermarket system and also get a coolent filter when you get that done. Afterwards, DRIVE this truck as hard and often as you can.
You can read MY story here: https://www.ford-trucks.com/forums/9...y-to-atns.html
Damn, after reading that Im back to square 1... At least as it sits now I can get a good trade in for it, or I spend $8k on this one to make it reliable...
That is what I am doing now. Spending about 3 grand and doing all of the work in my shop instead of a new truck. Tranny was done last year and truck only 58,000 on it.
You would measure them with gauges, either mechaical or digital like a scangauge or edge insight or dash daq.
mnwcine
09-03-2013 10:16 AM
