Delta variance
Old Sep 11, 2015 | 12:05 PM
Kemicalburns's Avatar
Kemicalburns
Delta variance
just wanted to get all your thoughts. on a cold soak I am only seeing maybe a degree and a half difference between the gauges.
first pic shows deltas while driving about 40mph with infrequent stops due to traffic
This is now showing after driving 60mph for about 10mins and then running a mild 25mph due to reaching more city streets, these deltas didn't reduce much more than a degree or two with the city driving.
Now I bought the truck from ford dealership with their 2yr premium warranty, if a cooler needs replaced yet no check engine light is present would/could this fall under warranty replacement.
Truck is stock 07 CC shortbed 4wd with 105k miles currently. I can offer some engine bay shots as well if necessary.
I also wanted to mention when towing my 7500lb trailer over the labor day weekend on a grade I would see 15-20* variance going 50mph , EOT never getting above 230 if I recall. My fan kicks on but the sound isn't consistent. it sounds like it revs up then down then up again, would that dictate a bad clutch fan?
Old Sep 11, 2015 | 12:24 PM
lupuseven's Avatar
lupuseven
7 degs is awesome!
a lot of folks see 5-8 Deg difference. Under 15 is the goal, your system is operating normally.
Old Sep 11, 2015 | 12:33 PM
navistarnut's Avatar
navistarnut
The SC II that I use for my '03 has the coolant temp shows as ECT..........am I missing something? Is this one showing the little f for degrees F water temp?
Old Sep 11, 2015 | 12:40 PM
WatsonR's Avatar
WatsonR
FTW is fresh water temp. That is preprogrammed, you probably entered an X gauge for it.
Old Sep 11, 2015 | 12:42 PM
navistarnut
I actually bought mine pre- programmed for my year, must be why
Old Sep 11, 2015 | 12:45 PM
WatsonR's Avatar
WatsonR
And all the readings are in standard US numbers not Celsius... I can't spell it, but u know what I mean.
Old Sep 11, 2015 | 01:02 PM
69cj's Avatar
69cj
What can't you spell? Celsius or Fahrenheit? lol
Old Sep 11, 2015 | 02:00 PM
BryanStein's Avatar
BryanStein
The proper delta (at least as generally agreed on this forum) is warm it up for 15 to 20 minutes doing 65. Then find a flat streak of road (as much as you can) and run 65 for about 5 to 10 minutes. Only at this steady state do deltas mean much.
I like to drive mine 80 mph for 15 minutes then drop down to 65 for 5 to 10 miles. This way, I can see the temps decrease and stabilize. Then I know i'm at a steady state.
My cooling system is spotless, my water pump has 20k miles on it and my oil cooler has less than 5k on it. Did the work myself so I know its spotless. My deltas measured as above are 6 to 7 degrees.
Deltas when towing can vary quite a bit based on load, grade, speed, etc. Your 230 EOT while towing is good. I push an EOT of 245 while towing, but I run 80 mph and tow a 32 foot TT that is essentially a big wind sale.
I know 245 is too high, but I'm running synthetic and i'm working on getting it down by slowing down and changing thermostats. If that doesn't work, I'll look elsewhere.
Old Sep 11, 2015 | 02:23 PM
KDAVID1's Avatar
KDAVID1
Mine run (under proper testing) between 6-7.
Running on the interstate at 70 for 3 hours (just last weekend) it runs 5-8 split.
Old Sep 11, 2015 | 02:37 PM
WatsonR's Avatar
WatsonR
Then I must be lucky....
Oil cooler is 40k and my delta's were 3-5 even on a real hot day.
New water pump and coolant change 2 weeks ago to EC-1, I'm now at 1-3 difference. And towing the boat or camper (8k) I'm at 5-10 difference and it's mid 80-95 heat here.
Until now, I was flushing every 15k and I may still do that.
Fix it guy here, sepelling was not my favorite class, tock tow trys to get out of that class....yuck! Still hate it!
Old Sep 11, 2015 | 03:02 PM
r2millers's Avatar
r2millers
Looks like all is well with your oil cooler and fan clutch.
I run very similar numbers with my 07 and my clutch kicks in at 219-220 and cycles as you indicate.
Good luck.
Old Sep 11, 2015 | 05:26 PM
Kemicalburns
I appreciate the feedback thanks
Old Sep 13, 2015 | 10:04 AM
coolfeet's Avatar
coolfeet
I flushed my coolant on a used e350 with extremely dirty coolant compared to any gas Vehicle.
I ran it for 30 minutes at 65-70 mph.
ECT 181. EOT 190. Delta ranged from 6-11.
Seems like the T stat is not working properly.
I am running reverse osmosis water until I flush with restore.
Should I change t stat?
Old Sep 13, 2015 | 10:30 AM
WatsonR's Avatar
WatsonR
yes! At that temp your truck is fueling heavy to achieve 185*
Old Sep 13, 2015 | 09:19 PM
Thor'sHammer's Avatar
Thor'sHammer
Here's the problem I see with the "delta" procedure.
Supposedly, this process was created to give technicians a way to determine oil cooler health. I think it's deeply flawed, simply because of the parameters required. 65MPH yields a different RPM and load with trucks configured with different gear ratios and GVWR. A general speed, such as 65 MPH, is simply not a good parameter to use in a test that can be so crucial to the engine's health. A better procedure would be a set RPM to maintain at a specific GVWR.
