VC-9 Before and after; Worth the money
Prior to using VC-9. My temps. were at ect. 196, eot.206, was the lowest, and avg.ect 208,eot.220, with no load. hit 216,eot 230 towing 7,000 lbs. While this isn't outrageously high it is higher than others posted, I did a flush a year ago with simple green and a Prestone cleaner..The coolant has been very clean and I have the coolant filter which has shown no particles.
While doing the VC-9 flush I drove on the hiway and after 45 minutes started seeing a drop in temps.( I ran the flush for a hour and half.) The lowest temps. now read ect. 189. eot 193. Avg. temp. is ect 191 eot.194.The spread pulling hills did not go over 8 deg. and never went above 200 on either eot. or ect. It also seemed to cool quicker, but I have no times to verify how much faster. This is all at comparable outside temps. give or take 2 deg. With ac. on high.
The flush water with VC-9 was black and dirty. And did 7 flushes to get to clear water. The coolant filter had a bunch of white sand and some metal flakes which about one third was rusty. This was just from banging on concrete floor.
I thought I had a pretty clean system before and was totally amazed at the results of the VC-9. The results are better than I could have ever imagined. Just thought this info might be useful to others who are hesitant to spend the money and time for the VC-9.
Rock1074; Your welcome. I figured the results were worth mentioning since it is expensive when you figure in all the flushes of distilled water, it is also time consuming. But it was exciting to watch the insight temps. slowly come down and narrow the gap between eot. and ect. I had read to run about 30 minutes but found things starting to change the most after 45 minutes. Speed was 60-70 mph.
I wonder if this could help me
Thanks flamebuster, this is very interesting. I currently have a 30 degree spread. What's the longest you should keep the VC-9 in your system? I'm temped to try this for as long as possible to see if it helps. The dealership just recently did a flush with the VC-9 a few months back, but not very long and only rinsed once with tap water.
https://www.ford-trucks.com/forums/8...tructions.html
thanks for the information bpounds and Cheezit. I didn't remove the thermostat and never even thought of pulling the block plug. It took a few more flushes to get clean water draining out, but hey I am still learning. I was worried about leaving the VC-9 in too long but after seeing the temps. drop after 45 minutes I figured it was just starting to do some good cleaning so I just kept heading down the hiway.. I had read in a post that it was better to drive at higher speeds instead of just around town. Guess that part was inaccurate but the trip was funner than watching a truck high idle in the driveway.lol.
Cheezit why remove the starter?
Here's a whacko thought: How much clearance is between the starter and the right side of the block?
Is there enough room to install an elbow into the hole for the drain plug, and then a 2-3 inch pipe nipple to get the plug down far enough to NOT have to remove the starter on subsequent flushes?
-blaine
-blaine
Thanks for the great info flamebuster. I'm due for a coolant flush and I've been concerned about higher than normal coolant temps and so hopefully using VC-9 during the flush will yield me the same results that you have seen. This is a great topic for anyone who does their own routine maintenance.
Thanks cheezit for explaining the starter removal.
