2012 Wish List
Old Oct 19, 2010 | 02:31 PM
  #61
srkr's Avatar
srkr
I can't believe noone has said this yet...
A true DEF gauge. To know how much Exactly is in the DEF tank.
Shane
Old Oct 19, 2010 | 04:24 PM
  #62
Fat_Tire's Avatar
Fat_Tire
Shane
No kidding! Unbelievable that its not standard.
How about an option for decent tires. Continental? Come on! What a waste of rubber.
Auto-locking (electric locking) tailgate. Duh! And maybe quick removal should be an option. I'm tired of tailgate theft!
Synch Traffic, Directions and Information should be available with the nav unit!
Old Oct 19, 2010 | 04:32 PM
  #63
sdetweil's Avatar
sdetweil
Shane
but why do you care?
you got 800 miles of warning. I think thats 2 or 3 tanks of fuel.. so, refill when u need it..
you shouldn't have to manage it that close that you need a separate gauge.
Sam
Old Oct 19, 2010 | 04:37 PM
  #64
EpicCowlick's Avatar
EpicCowlick
I'm also thinking it would be pretty difficult to use a float-type sensor in a solution that will freeze solid in the winter time. That would have to be a pretty robust float to survive all that freezing and thawing.
Old Oct 19, 2010 | 04:41 PM
  #65
srkr's Avatar
srkr
Sam
Peace of mind, I tow an Airstream and sometimes I don't get to a public place for a week or two. Towing back roads place to place..The gauge would be VERY helpful. Or I should top off everytime I leave for a trip? Or drag around 2.5 gallons? Thats why I care. BTW. Everyone scenario isn't your scenario.
Here is another Perfect example why I care,
I had 2.5 gallons added 2,500 miles ago.Supposedly full then In about 3 weeks going to a secluded place in the mountains in Arkansas. No light to fill up. I would like to know before I leave If I need it. Like I said, Peace of mind.
Just say'n
Shane
Old Oct 19, 2010 | 04:45 PM
  #66
srkr's Avatar
srkr
That brings up a good question and I do believe it was touched on here, but I can't find it.
How long does it take for the def fluid,being almost full to thaw? For example hunting or way up in the mountains and my truck sits for 2 days at 27 degrees. Would there be any issues about starting and driving off? Would it go into Idle only mode until it thaws? Is there a seperate heater on the def tank when the truck is started?
Hmmmm...
Shane
Old Oct 19, 2010 | 04:48 PM
  #67
EpicCowlick
Ford figured this out. They included heating elements in the tank to avoid precisely this problem. The DEF will thaw in time for when it is needed. They also have a pump that withdraws the fluid from the lines each time the engine is turned off to make sure the lines won't freeze. That is the gurgling sound you hear when you shut down the truck.
Old Oct 19, 2010 | 04:53 PM
  #68
sdetweil's Avatar
sdetweil
I understand.. I am business justification kind a guy.. what I get to deal with all the time.. so a stated requirement needs to be understood.
Ford will need to understand the justification to develop a cost, which is design, manufacture, document and support..
I understand your use case, thank you.
For your use case with the existing equipment, I personally think for things like tools, you should carry a refresh supply with you. I bet you do that with oil & filters too. (I would)
And, it doesn't matter what I think.. I'm just asking questions, hopefully learning.
Sam
Old Oct 19, 2010 | 05:05 PM
  #69
srkr's Avatar
srkr
Sam
Not to beat this horse too much, heated/cooled seats are a requirement, dual temp controls,.etc.?..more of luxury items I'd say. The gauge on my part would be needed and appreciated. The less I lug around, equipment,tools the better.....Lets really go way out there. Lets say I brought 2.5 gallons and it's frozen.....but I wouldn't let it because you never know...It would be inside with me sleeping under the covers. Not peace of mind. IMO
Not Necessarily standard equipment but an upgraded option would be nice. I know after the first year or so, I'll learn the pattern of this truck and it won't be any issue, but to newbies,which we all are it would be a great "option" bonus.
On a seperate note, Maybe I'm in the minority bracket.
Shane
Old Oct 19, 2010 | 05:23 PM
  #70
rickatic's Avatar
rickatic
Shane,
I usually agree with you but I may be confused. The message center will tell you if you are above or below 1/2 full. Sometimes when mine actually says 1/2 full it will only take 2 gallons. If you are leaving on a trip and the tank is over half you can go 3000 miles. If it is under half, fill it and you can go more than 6500 miles. No need to carry any with you that I can see. That being said, I hear if you keep your DEF stash in the bathroom closet, no one knows it.
Regards
Old Oct 19, 2010 | 05:28 PM
  #71
srkr's Avatar
srkr
Originally Posted by rickatic
Shane,
Regards
I'm worried that TOWING in Mountains and possibly extended idle times will use a considerable amount of def...Am I wrong?
Basically before I go anywhere I should top off....Like I said the gauge would be a nice option.
Shane
  #72
Fat_Tire's Avatar
Fat_Tire
I see what you guys are saying but I would still rather have a gage that tells me the level of the DEF. They already have a sensor that monitors and reports when its half empty. Why can't they just update the software to show the level.
Old Oct 19, 2010 | 05:29 PM
  #73
Fat_Tire's Avatar
Fat_Tire
Shane
Or... a leak.
Old Oct 19, 2010 | 05:31 PM
  #74
srkr's Avatar
srkr
Originally Posted by Fat_Tire
Or... a leak.
Thanks for that Worry, now.....
See a gauge would be VERRRYYYY beneficial.
Just say'n,
Shane
Old Oct 19, 2010 | 05:32 PM
  #75
rickatic's Avatar
rickatic
The worst case scenario posted so far is around 5000 miles per tank of DEF. Ford has said that high loading and heavy pedaling is what consumes the most DEF. I think you are worrying needlessly
