EGR Block Off
Old Aug 9, 2010 | 10:47 PM
Jayman405's Avatar
Jayman405
EGR Block Off
dose anybody know where i can get or how to make a EGR Block Off for a 94 with a 300?
Old Aug 10, 2010 | 12:04 AM
hittman1422's Avatar
hittman1422
would it even be possible to do that with EFI??? i'd think it would screw with the computer
EDIT: could do a carb swap
Old Aug 10, 2010 | 08:45 AM
Brigart's Avatar
Brigart
RJM Injection Tech EGR Eliminators
Old Aug 10, 2010 | 09:09 AM
AbandonedBronco's Avatar
AbandonedBronco
Why do you want to block it off? EGR is actually beneficial to your engine, and in some cases can increase fuel mileage.
Old Aug 10, 2010 | 09:23 AM
Ford_Six's Avatar
Ford_Six
With EGR, you can run higher compression and more aggressive timing while burning less gas. It is beneficial to a gas engine. Now if it was a diesel, I'd have plenty of advice on removing it-
Old Aug 10, 2010 | 07:42 PM
Jayman405's Avatar
Jayman405
the reason why im trying to remove the egr is cuz its gone bad
Old Aug 10, 2010 | 09:55 PM
Harte3's Avatar
Harte3
Is replacing it not an easier option than trying to eliminate it and most likely ending up with no improvement or even a worse running engine?
Old Aug 12, 2010 | 08:43 PM
Roader's Avatar
Roader
You could cut one out of a piece of sheet metal. The bottom of a sardine tin would work fine. Just use two gaskets.
brkncly
6.4L Power Stroke Diesel
Aug 2, 2012 08:25 PM
parkland
37
Oct 28, 2011 02:09 PM
hwybee22
Dec 26, 2009 08:52 AM
KRDiesel
Jul 29, 2009 02:27 PM
glm racers
Oct 30, 2008 11:20 AM
