Sponsored by: Real Truck
Need ICP sensor help (01' F350)
Old Aug 8, 2010 | 01:18 PM
DRAGN3's Avatar
DRAGN3
Hello forum,
I need help locating my ICP sensor and determining if it is my problem. I just bought the truck and apparently it had been warmed up already when I looked at it so the truck would crank and run fine. Now, when I first crank the truck in the morning it will barely crank and it runs like crap for about fifteen minutes then it runs pretty good and it will crank up easily for the rest of the day. So,
I took the truck to a local diesel shop and they put it on a snap on tester. It should numerous things: One of the main issues that I saw was a problem with #1 and #2 cylinder. That showed up on two seperate test. I think is said something about pressure. The shop called the Ford dealership and they told them to replace the ICP sensor. The shop sent me to pick one up. I now have it and I cant seem to find it on the engine. I know this is a long winded question but I really would appreciate any and all input.
Thanks in advance for your help.
Old Aug 8, 2010 | 05:02 PM
DRAGN3's Avatar
DRAGN3
Well, after some research I found where the sensor was located and installed it. It did not change a thing. The check engine light is blinking on and off and it smokes lightly when its idling.
However, it does seem to run slightly and I might slightly better.
Old Aug 8, 2010 | 06:28 PM
F350-6's Avatar
F350-6
Unplug the ICP sensor while it is idling and see if it smooths out any.
How many miles are on your engine oil? What type of oil is it? Is it full? Your fuel injectors run off of engine oil, so making sure you have clean, full oil of the proper grade is critical.
Welcome to FTE.
Old Aug 8, 2010 | 07:25 PM
DRAGN3's Avatar
DRAGN3
Thanks for the reply. I had the oil changed as soon as the bought the truck with rotella t. It is full. After I changed the icp sensor I unplugged it to see if the engine would start and it did and idled fine.
The one thing I did notice once I put the new sensor on was that when the engine cranked it lopes three times before it smooths out and idles. I guess that makes since. It drops up and down in rpms three times then idles. I have no idea if that means anything.
Old Aug 8, 2010 | 07:44 PM
F350-6's Avatar
F350-6
If the truck idles better with the ICP unplugged, either the new sensor is bad, or you've got a short in the wires going to the sensor.
Unplugging the sensor will cause the CEL to come on and will throw a P1280 code, but it also causes the computer to run the truck based on default values instead of the readings from that sensor.
Old Aug 8, 2010 | 09:31 PM
DRAGN3's Avatar
DRAGN3
After I removed the icp sensor I noticed the hole it came out of was full of oil. Was it supposed to be?
Old Aug 9, 2010 | 05:47 AM
F350-6's Avatar
F350-6
Yes, that's what the sensor reads. Oil pressure in the rail.
Old Aug 9, 2010 | 09:19 AM
DRAGN3's Avatar
DRAGN3
I was pretty sure it was supposed to be. I know Im a newbie fella's! Thanks for bearing with me here.
It still cranks and runs like crap for about 15 minutes or so. I fired her up this morning hoping for better results but it didnt happen.
Old Aug 9, 2010 | 09:48 AM
Pocket's Avatar
Pocket
Next time it sits overnight, try plugging in the block heater. Then see how it cranks the next morning.
navistarnut
Oct 19, 2018 01:53 PM
nandos_camaro
Aug 7, 2017 09:20 PM
Magilla_v6.0
Oct 31, 2014 08:41 PM
jshalala
19
May 29, 2014 07:20 AM
bubblechaser
Nov 13, 2013 09:16 AM
