1/4" will be fine, but why not just go 3/8? its a little overkill but better to be over done then under done. i went 1/2" on mine, with 3x6x1/2" cross bar. it weighs about 150 lbs but my frame will fall off before that thing goes. if you go to a metal place, they will usually sell scrap pieces. you can get a remnant piece of sheet. you pay per pound. think mine cost me about a dollar a lb when all was said and done. the receiver tube has to be specific size. tell them you want it and they will sell it by the ft. think it was about 11 bucks a ft here.
yes put in sprayer and do the bottom where you can also. i saw al. sheet with the cheapest plywood blades i can find and run them backwards on cir. saw. works great for me.
On the bed - looks good as is, not too sure about framing it tho, but do add some sort of stake pockets to the sides and/or eye-bolts to the floor for tying things up - heck I got 1/2" eye-bolts in my bed, and it's a factory pickup bed that switches duty between camper and 5th wheel as needed.
Framing the sides and rear with steel would be the easiest way to put stake pockets on the sides and back.
Those along with a headache rack or at least a bed front will be needed if you plan on hauling anything and have it make it to where you are going unless you tie down each piece.
If you go the tie down route, add plenty of tie downs so you have enough.
Thanks LCAM, Thanks really what i wanted to hear. My last truck with an all metal bed had (4) 1/2" eye bolts in the corners and it worked well. I thought the bed looked good on that truck too.
I'll have to find a pic of it...
I'm sure i'll add some tie downs, but the plan is 10-12" tall sides (semi-permanent) and front. Thought it would be easier, 3" angle is about $3 a foot (that's an old price).
I'm gonna have to do some thinking on how to make some secure sides that will look good with whats already there...
