I've got the old taillights if someone need them...
your not done yet are ya? if it were me, id get either flat stock steel or aluminum. maybe 4 or 6" wide just to run under the strips to hide the cross pieces. would clean it up nice.
maybe a custom rear bumper OR lift yours to match up with the bed better.
Ditto on what oreo said and put a headache rack on it :D
I agree you should frame it out using steel. I look at 100% wood flatbeds the same way I look at PVC headache racks, and I curse Home Depot for their existence... :-X15
Since you didn't use pressure treated, you should pick up a can of deck stain & sealer and roll the whole thing with it. Otherwise that wood's going to go straight to hell when the rainy season hits. It'll also darken it up, keep it from getting shredded when you put anything on there, and make it look 1000x better. Worst case if you don't want to lift the bumper to match, use a piece of 1x8 or 1x10 bolted on the back to fill the gap. |
That looks good, I agree with the census here though. I used treated wood and framed the edges and cross supports with angle iron. The diamond plate aluminum I used I bought at my scrap yard. Word of wisdom though, that aluminum is HARD to cut. If you don't have a plasma cutter, the only thing you can use is a carbide tipped framing blade on a skill saw. Plan on using about four or five of them though....
I would have rather used steel and painted it. I think that would have been easier. I still haven't gotten my headache rack built or my fuel fill tubes relocated right. http://i44.photobucket.com/albums/f5...r/DSCN1005.jpg |
A note.....don't do the sides like this.....Makes it hard to get the wheels on and off.....
Originally Posted by oreocreaming
(Post 9194284)
(Post 9194288)
Originally Posted by WarOzz
(Post 9194452)
Originally Posted by ihateminimumwage
(Post 9194500)
Harsh toke Dude... :p Since you didn't use pressure treated, you should pick up a can of deck stain & sealer and roll the whole thing with it. Otherwise the that wood's going to go straight to hell when the rainy season hits. It'll also darken it up, keep it from getting shredded when you put anything on there, and make it look 1000x better. The 4x4's are treated, but the rest will get deck sealer in the near future. Worst case if you don't want to lift the bumper to match, use a piece of 1x8 or 1x10 bolted on the back to fill the gap. See above. That bumper is going to go away... I was looking at hitches and all the ones i saw V5 rated had 1/4" steel sides... And the plate that was in the bed is 1/4"... Ihateminimumwage (me too:D), would you feel better if i trimmed the sides and back with 3"x3"x1/8" angle iron? I need something to put stake pockets on anyway... The original plan was a steel frame with 3/4" plywood decking, but i did this because of money limits... The hybrid bed may still get built someday... |
Maybe you're planning to put fenders on there, and box sides? I did that with my Toyota years ago. got some fenders cheap (I think they were for utility trailers). Got 4 of them and doubled them up/welded together 2 on each side for required width. Then just cut a square cutout on y our wood bed, cram the fenders up in there and lag screw them in. It felt kind of mickeymouse when I was doing it but it's been tough and ran that way a long time with no trouble. Not sure if the Ford would need the suspension travel that my yota did, though. I also used P/T wood and framed up box sides so I could put on my stock canopy and boat rack.
:) I like trucks like this.... |
Thanks man. I might hang some conveyor belting on the 4x4 behind the tires, but i doubt i'll do any cutting on the bed for fenders.
Definatley needs sides and a headboard though... |
Originally Posted by elinmon1976
(Post 9194555)
Yeah Warr....I had REALLY cheap blades.....no lube.....
We had no clue what we were doing.... I tried sawsall blades of all types but no lube. I wondered if the poly in the aluminum makes a difference? It's funny, I work on the other side of metal so I know what type of aluminum and other non ferrous metals are but no clue how to work with them. Thanks for the tip man....Still have a lot of cutting to do on this thing.... |
Frame that thing out and install stake pockets :-X22. No real point in a flatbed without options to add sides or have tie down points available when need be...
Sounds like you've laid out your plans for it, and it should be a good solid flatbed when it's done. I'll never take back my stance on Home Depot, and the abominations it provides people the supplies to create...:D |
It looks way yonder better than all that rust,its a good starting point ,you can always add and modify later,however I do wish it were pressure treated wood,like already stated some good stain/sealer is a must. Put it in a pump up spray bottle and soak the snot out of it........
