Truck is BADLY out of alignment....even after alignment was done
Old 08-05-2010, 01:23 PM
BlackNGoldRules's Avatar
BlackNGoldRules
BlackNGoldRules is offline
I just took my ranger to my local tire place to have an alignment done. Before the alignment, the truck was turning to the right on its own pretty badly. Well, after the alignment was done, it's still turning to the right pretty badly and now the steering wheel isn't centered either when I'm going straight. The horn is at about 8 and 2 o'clock to the left on my steering wheel when I'm going straight. And I have to pull the steering wheel to the left when going straight. They did tell me that my one front tire has a broken belt in it and it's causing my truck to shake above 40mph. I'm getting the tire replaced tomorrow. Could one bad tire throw a vehicle out of alignment as much as I'm describing, or could there be something else that is wrong? I went back there yesterday and told them how it's still badly out of alignment after the alignment they did and he said it could be that bad tire. Anyway, any advice on this is appreciated. Thanks.
Old 08-05-2010, 01:30 PM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Then take it back and tell them to do it right. Even with a bad tire it should not pull that much.
Old 08-05-2010, 01:51 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
A severely seperated tire can cause a pretty bad pull. If new tires don't allow the truck to drive straight, take it back to the alignment shop as many times as required to either get it right, or get a refund so you can take it somewhere they *actually* know what they're doing.
Old 08-05-2010, 01:52 PM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
If it still does the same thing after the tire is replaced, then I would ask for my money back and take to someplace else.
Old 08-05-2010, 02:34 PM
BlackNGoldRules
The alignment was actually free, but I'll get that tire replaced and see what happens. I just looked at the tire and I can see some tread sticking up in a row long ways over the tire. I'll keep you guys posted. Thanks.
Old 08-05-2010, 03:26 PM
wtroger's Avatar
wtroger
wtroger is offline
You can't tell any thing with a bad tire on it. They can pull severly with a seperated belt. I can't believe they would have fooled with the alignment with a bad tire on it. You really need to have it realigned after the tire(s) get replaced. As for the steering wheel being off they tried to set the toe in and only made the adjustment on one side. Free might not have been so free. Somebody will have to redo this alignment.
Old 08-05-2010, 08:44 PM
reddog99's Avatar
reddog99
reddog99 is offline
It's possible (in addition to the bad tire) that some suspension components are worn. All the alignments in the world won't help if that's the case.
Old 08-06-2010, 04:33 PM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
i would grab a tape measure and measure the distance from the center of one tire to the center of the other tire on the fronts of the tires, then do the same for the back of the tires, and post up what the numbers are.
Old 08-09-2010, 06:23 PM
BlackNGoldRules
Well, just to update you guys, my alignment problem appears to be solved. I had both front tires replaced and it seems to be riding perfectly straight now. Another problem has popped up which I started another thread about, but the alignment seems to be good now. Thanks for all of your help guys.
Old 08-09-2010, 07:14 PM
jecsd1's Avatar
jecsd1
jecsd1 is offline
bingo!
Get TWO new front tires and make sure all 4 are set to factory air pressure. If it still pulls, take it back and demand they perform the alignment again until it's correct. If they give you BS demand your money back and take it somewhere else.
granny_rocket
22
12-02-2015 10:17 AM
jonrjen
6.7L Power Stroke Diesel
02-20-2015 07:26 PM
devongarver
1999 to 2016 Super Duty
63
11-04-2014 07:43 PM
nomad221
08-01-2013 11:49 PM
2002f350sd
03-18-2011 05:04 PM
Quick Reply: Truck is BADLY out of alignment....even after alignment was done
