2003 Ranger Dome Light Problem
Old Aug 8, 2010 | 11:34 PM
bronco549's Avatar
bronco549
Hello Everyone--
--I'm new to the forum, but have a question about my 2003 Ranger (4x4), 4.0 engine.
--I can't get the dome light to go off. I've checked the light switch to make sure it is not in a position to make it stay on and it isn't. The light has stayed on all night before so I removed the bulb to keep it from killing the battery.
--I can't find a door switch that controls the light when I open the door. Any suggestions as to what the problem is and how I can find the door switch or button control so I can change it out?? My Haynes manual is no help.
Old Aug 8, 2010 | 11:41 PM
grandmas77f150's Avatar
grandmas77f150
Do you have a 4 door?
Sometimes if one of the other doors isn't closed all the way, the light will stay on
Old Aug 9, 2010 | 03:50 AM
03 Maz B23's Avatar
03 Maz B23
The dome light switch is built into the door latch mechanism. Can't see it unless you pull door panel. Have heard of people using wd40 with the wand attached to spray into mechanism from the outside to make it work properly.
Old Aug 9, 2010 | 10:00 AM
bronco549's Avatar
bronco549
2003 RANGER DOME LIGHT PROBLEM
Thanks 03 Maz B23--Thanks for pointing me in the right direction--I wasn't even sure where to look. I'll pull the door panel and work from there. Will let you know what happens.
Old Aug 9, 2010 | 05:22 PM
03 Maz B23's Avatar
03 Maz B23
Here is a link on how to remove the switch to clean or replace it. I stand corrected on the use of wd 40. They recommend electrical contact cleaner.
http://www.therangerstation.com/tech...ontactPin.html
Old Aug 9, 2010 | 07:30 PM
Red2003XLT's Avatar
Red2003XLT
Pretty common with Fords especially Windstar minvans, a shot WD40 will fix it.
Critterhunter
38
May 26, 2017 01:05 PM
phillyken
Apr 2, 2016 09:44 PM
bluecobra
1997 - 2003 F150
Feb 29, 2016 10:17 AM
rpstrong
Dec 13, 2013 06:47 PM
slickrock01
Sep 28, 2009 09:40 PM
