T18 problems
Old Aug 4, 2010 | 03:26 PM
Keagangunner's Avatar
Keagangunner
T18 problems
OK..... I know this will sound stupid but here we go.
1.shifter goes into transmission.
2.Cap holds it in.
3.Pin on shifter sheers (shifter will rotate 360 degrees)
How do you get the cap off#%^$^#%^
I have read the diagrams and appears to be threaded. but can not get it to move any help on this would be great. 1964 F100 custom cab 292Y with T18 divorced transfercase.
Thanks
Old Aug 4, 2010 | 07:43 PM
brown79's Avatar
brown79
yep. threaded i used a 24 inch pipe wrench and it was tight.
Old Aug 5, 2010 | 05:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1. Shifter goes into transmission.
2. Cap holds it in.
3. Pin on shifter sheers (shifter will rotate 360 degrees)
How do you get the cap off? I have read the diagrams and appears to be threaded. but can not get it to move any help on this would be great.
If you have a 1964, you do not have a T-18, it wasn't available until 1965.
You have the Borg Warner T-98. It uses the same shift lever retaining cap as the T-18 (8MTH7220), which threads on/off.
Once you remove the cap, you will see the shift lever retaining pin (COTT7B125A-5/8" x 1/4" diameter). You cannot see it beforehand, as it's covered up by the cap.
Be very careful if using a pipe wrench to remove the cap, using this method may cause the cap to become oval. It may come off, but will be damaged beyond repair.
Old Aug 5, 2010 | 06:19 AM
Keagangunner
Hey thanks all for your help, it is 64 4x4 shortbed customcab.
I will try this evening to get it off , if all else fails angle grinder and new cap thanks
Old Aug 5, 2010 | 10:26 PM
flipklos's Avatar
flipklos
Call me nuts, but the one on my 64 has two flats to put a wrench on it.
Old Aug 6, 2010 | 08:22 AM
Keagangunner
Yep it does but would rather buy a cap than wipe the threads off the top of the case.
tashbyl
Feb 5, 2022 02:39 PM
1918ALF
Jun 1, 2016 09:43 PM
Ken Blythen
Jan 9, 2013 12:14 PM
earthquake68
Jan 11, 2012 12:18 PM
cr8zy_vws
Feb 15, 2011 05:11 PM
