Help!!!!
Old Aug 7, 2010 | 03:22 PM
  #31
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Check your fuse box in your engine compartment.
The Truck
Old Aug 7, 2010 | 03:31 PM
  #32
Monster Stroke's Avatar
Monster Stroke
Well fuse 45 and 43 arnt getting power. my understanding is fuse 64 powers them. But again. Where is fuse 64 at???
Old Aug 7, 2010 | 03:34 PM
  #33
Monster Stroke
The Truck
Where is that?? The only thing i found in there was like 7 or 8 relays in two seperate little boxes
Old Aug 7, 2010 | 03:43 PM
  #34
tdpower's Avatar
tdpower
The Truck
In 2002 they moved all the fuses to the cabin.
Old Aug 7, 2010 | 03:51 PM
  #35
Monster Stroke
So the one fuse box i have is it??? Oh and fuse 45 and 43 now have power.. i didnt realize the key had to be on. But fuse 23 still isnt getting any power...
Old Aug 7, 2010 | 03:59 PM
  #36
tdpower's Avatar
tdpower
Did you check eec/pcm relay with it unplugged? Should be 302. Yes that is the only fuse box you have.
Old Aug 7, 2010 | 04:01 PM
  #37
Monster Stroke
I checked and it has power always. and key on power... Im not really sure how to check the ground...
Old Aug 7, 2010 | 04:07 PM
  #38
tdpower's Avatar
tdpower
I would check that pcm diode as well. It should only have continuity in one direction. If you reverse the leads no continuity.
Old Aug 7, 2010 | 04:18 PM
  #39
Monster Stroke
Where is the diode at??
Old Aug 7, 2010 | 04:32 PM
  #40
tdpower's Avatar
tdpower
I don't see it listed in the 2002 manual. In my manual it shows a pcm diode and ac clutch diode.
satsol67
1983 - 2012 Ranger & B-Series
Apr 8, 2009 02:24 PM
nativejammer
4 Cylinder Engines
Nov 22, 2007 11:59 AM
mike_23us
26
Dec 30, 2005 04:50 PM
pitty
Oct 3, 2004 08:04 PM
pntrbil
Aug 22, 2002 03:03 AM
