Help!!!!
Old Aug 4, 2010 | 06:31 PM
Monster Stroke's Avatar
Monster Stroke
I jump power from my cigar lighter fuse to fuse 23 and then my truck will start and the scanner works... i just tried driving it but everything is in limp mode so it moves like a snail. lol Ive checked fuses, relays, fusiable links.... I swapped every relay with the blower motor one and nothing....
Old Aug 4, 2010 | 06:35 PM
zx250's Avatar
zx250
Of the next Riffraff East
Anything noteable happen just before this problem occured? Rain, Bump up, Engine work? Might want to check the main wiring harnesses at the drivers fire wall. Have been known to come unplugged.
Old Aug 4, 2010 | 07:32 PM
tdpower's Avatar
tdpower
Still sounds like you have a problem with the inputs to the pcm relay. To clarify it a little more.
1St find B+ (this should be hot all the time)
2nd find key pwr ( should be hot with key on)
If those two check out, probe the two remaining terminals for continuity to ground and should find the ground. The output will probably be a little harder to check. All this is done with the relay unplugged. Sounds like you have something else going on but have not really gone into that.
Old Aug 4, 2010 | 08:48 PM
Monster Stroke
I had the power for my gauges wired into fuse 23. but i didnt realize when i did it that i had it powered from the side of the fuse that gets the power not sends it out. so the line wasnt actually fused. something grounded out and my gauges quit working. but it blew whatever powers fuse 23 not the actual fuse cause it was on the wrong side. thats why i checked the relay right away but nothing was wrong with it... thats why i wanted to know what powered fuse 23... but i'll check the inputs as soon as i get home
Old Aug 4, 2010 | 09:40 PM
tdpower's Avatar
tdpower
The more you post info up front the more we can help you out. IDK but going to bed.
Old Aug 4, 2010 | 10:05 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Just looked at the print a little harder and it looks like the PCM relay is not actavated until the key is in the on mode. Look at fuse #64 it suplies power to the relays coil.
It also suplies power to these other places.
Fuse#45= Accelerator Pedal Position Sensor
Fuse#43= Fog Lamp realy
strait from fuse# 64 to Waste Gate Solenoid and Fuel Bowl Heater
So with the Fuel bowl heater in the pic. I would look at it real hard
The Truck
Old Aug 6, 2010 | 10:05 PM
Monster Stroke
Ok guys. Where the hell is the pcm power relay located at????
Old Aug 6, 2010 | 10:22 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Central Junction Box (located on drivers side in engine compartment beside brake master cylinder)
Hope this helps
If the pic is not showing up you might want to look in your ownners manual
The Truck
Old Aug 7, 2010 | 01:29 PM
Monster Stroke
huh in my truck its under the dash. But my manual has that one marked as eec relay??
Old Aug 7, 2010 | 02:43 PM
Monster Stroke
Ok I've narrowed it down to a blown #64 fuse. But where the hell is it?? My manual skips from 48 to 102
Old Aug 7, 2010 | 02:59 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
It is also in your C.J. Box in the row that starts with fuse #34 thru fuse #48. How ever I would Unplug Your Fuel Bowl Heater. More then likely it is shorted out. The plug for that is on the lower right of the fuel bowl (facing the truck) on the back side of the fuel bowl.
The Truck
Old Aug 7, 2010 | 03:05 PM
Monster Stroke
Its actually been unpluged for like the last year on accident... just found that out yesterday
Old Aug 7, 2010 | 03:07 PM
  #28
Monster Stroke
ok and as far as i can see fuse # 64 is not in that row... its numerical from 34 to 48
Old Aug 7, 2010 | 03:12 PM
  #29
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Ok well that takes that out of the pic. Now we have a Short to find !!
or that fuse is just going to blow again.
The Truck
Old Aug 7, 2010 | 03:18 PM
  #30
Deluxe06's Avatar
Deluxe06
4000 rounds a min
The only things conected to that fuse are the.
PCM relay with the PCM Diode
fuel bowl hearer
Wastegate control solenoid.
when you turn the key on
The Truck
