96 Ranger 2.3 engine problem
Old Oct 2, 2004 | 08:31 AM
pitty's Avatar
pitty
96 Ranger 2.3 with 145,000 miles. Engine suddenly started to severly spitter, sputter & break down. Converter was red hot so I assumed it was plugged. Installed new converter and the problem was still there and the new converter was getting hot. Installed new timing belt, plugs, wires, & fuel filter. Still no help. Local mechanic analyzed it as the cam sensor. Installed a new sensor and the problem is still there. Motor starts & idles fine but as soon as a load is put on it, the motor breaks down so bad it is not drivable. Any ideas would be appreciated. Thanks
Old Oct 2, 2004 | 08:11 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Are you getting any codes? Hows the fuel pressure? Hows does it react if you just rev it up without a load.
Old Oct 3, 2004 | 12:43 PM
pitty's Avatar
pitty
Thanks for the response
Fuel pressure is good, recovers somewhat very slowly. I get code P0320 (ignition/ dist engine speed input circuit malfunction). Thanks.
Old Oct 3, 2004 | 08:04 PM
Ken00's Avatar
Ken00
NC1 CONTINUOUS MEMORY DTC P0320: ERRATIC IGNITION
Continuous Memory Diagnostic Trouble Code (DTC) P0320 indicates two successive erratic Profile Ignition Pickup (PIP) pulses occurred resulting in a possible engine miss or stall.
Possible causes:
Loose wires/connectors.
Arcing secondary ignition components (coil, wires, plugs, etc.).
On-board transmitter (2-way radio).*
Are any of the above present?
*Verify all 2-way radio installations. Carefully follow manufacturer's installation instructions regarding the routing of antenna and power leads.
NEMOTORCARS
6.7L Power Stroke Diesel
40
Dec 31, 2019 10:59 AM
StangStang
Aug 23, 2016 10:15 AM
'04F250SuperDuty
Apr 17, 2016 07:59 AM
Grinder Man
Oct 10, 2014 09:35 AM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
