Sponsored by: Real Truck
5R110 HELP
Old Aug 5, 2010 | 01:01 PM
Toyman's Avatar
Toyman
ok, according to the Midtronics tester.....the diode ripple is normal. Show the alternator would not be the culprate.
At least that's one other possible problem checked and eliminated. I will take the kick panel off by the e brake tonight and see what the harness and connection looks like.
I was just thinking that the cab was off also to replace the head gaskets so I will double check the bulkhead connections at the firewall as well.
Old Aug 6, 2010 | 08:21 AM
Toyman's Avatar
Toyman
didn't get a chance to look the connectors over last night. Hopefully today or this evening I can look it over and report back.
I hate when life gets in the way of chasing down a gremlin in my truck.
Old Aug 7, 2010 | 08:28 AM
Toyman's Avatar
Toyman
Well I'm not making any progress. I have inspected and shifted around the wire harness, from the transmission forward. It didn't make a difference. here is the best part, about an hour after I did that and drove the truck the light stopped flashing and it runs like a million dollars again.
This is getting very frustrating, I would have to lean toward the wire harness or the TCM itself.
Old Jan 5, 2013 | 09:42 AM
yoccm's Avatar
yoccm
Hey Toyman,
I am having just about the exact same issue with my 2006 250. I was just wondering if you ever tracked down the cause of the problem on your truck. It sure would be helpful in looking mine over. I have also checked over all the wiring, replaced the sensors, and had the alternator tested like you stated in your posts.
Old Jan 5, 2013 | 10:24 AM
Toyman's Avatar
Toyman
Yes, sorry I did forget to post the follow up from it. There is a wire harness from the trans to up by the firewall that needs to be replaced. Once I finally got ahold of it all my issue were fixed. Truck ran like a million dollars.
Old Jan 5, 2013 | 10:29 AM
yoccm's Avatar
yoccm
Is that the harness that runs from the trans and plugs in on the passenger side or the drivers side? I haven't been able to find a new harness online (I have been trying to locate one for a couple of days now). Where were you able to track one down?
Old Jan 5, 2013 | 10:32 AM
Toyman's Avatar
Toyman
Dealer only part, have to go through Ford. It's been a couple years now, but I think it plugs in on the right side, goes over the top and connects on the left side by the brake booster. It wasn't very much money for the part, and only took about an hour to change out
Old Jan 5, 2013 | 10:37 AM
yoccm's Avatar
yoccm
Alright... good stuff. Thanks for the info, and hopefully this will fix my truck as well. It has definitely been a long and annoying process trying to chase down that gremlin.
Old Jan 5, 2013 | 10:39 AM
Toyman's Avatar
Toyman
Good luck!!
SSirois
Sep 20, 2017 08:37 AM
Sara_gael
May 15, 2017 11:10 PM
KidWithTheLoudFord
Jan 23, 2016 07:52 AM
tfleming99
Modular V8 (4.6L, 5.4L)
Dec 23, 2015 08:56 AM
sadyedog1
Jul 11, 2011 05:29 AM
