4R100 shifting problems
Old May 15, 2017 | 06:36 PM
Sara_gael's Avatar
Sara_gael
I have a 2001 3/4 pickup. Sometimes the over drive light flashes. When it flashes it shifts really hard and sometimes it won't shift into 4th until I mash the overdrive button. Sometimes the light doesn't flash at all and it doesn't have any trouble shifting at all. Is it a solenoid? Or wiring issues?
Old May 15, 2017 | 07:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's impossible to say. Get the codes read and then we can point you in the right direction. The places that read codes free CANNOT read the codes you need. You need either a good independent auto repair shop or a Ford dealer.
Old May 15, 2017 | 07:48 PM
Sara_gael's Avatar
Sara_gael
Wev've scanned it and it's not throwing any codes at all
Old May 15, 2017 | 08:15 PM
andym's Avatar
andym
Then you're not scanning it with a reader capable of pulling the codes. The parts store OBD-II readers won't read them. You need a scanner that you'd find in a "good independent auto repair shop or a Ford dealer" as Mark said.
You can also read them for free with an app called Torque Pro for your Android and a bluetooth adapter. There is also an app called Forscan for Apple products and a wifi adapter. The adapters can be found on amazon and the apps are on the phones' app stores.
If the OD light is flashing, I guarantee there are codes to be read.
Old May 15, 2017 | 08:33 PM
jhl3's Avatar
jhl3
FORScan also works on Windows and Android. For diagnostic purposes, it is better than TorquePro.
The windows version of FORScan is free. Then you'll need an OBDII to USB cable which is less than $15
Here is the thread that you should read: https://www.ford-trucks.com/forums/1...ighlight=Cheap
As mentioned before, if the OD light is flashing there are stored codes.
Old May 15, 2017 | 08:40 PM
cps's Avatar
cps
subscribing ........
Old May 15, 2017 | 11:10 PM
misterfisher's Avatar
misterfisher
When mine did that is was OK for 15,000 Miles, then I limped it to a transmission shop for an overhaul..
shawbran
Nov 13, 2024 12:53 PM
RDockery
Apr 21, 2016 08:50 PM
scottddove
84
Sep 7, 2014 10:34 PM
cmiller1229
Mar 12, 2010 07:33 AM
rtpalin
1997 - 2003 F150
Mar 29, 2009 04:01 PM
