Sponsored by: Real Truck
5R110 HELP
Old Aug 3, 2010 | 07:49 AM
Toyman's Avatar
Toyman
5R110 HELP
I am getting an intermittent P0791 code. It is the intermediate shaft speed sensor (?). The issue is it doesn't come on all the time. Is this going to be a solenoid failing? When the light is on the truck doesn't go into 1st gear at a stop, but it will shift smoothly all the way to 5th and the torque converter will lock in the way it is supposed to. I have a few friend that are transmission guys and the are stumped. Could it be a wire harness, or could it be a soleniod, or could it be the TCM?
When I take it to the dealership they can't seem to find it, mainly due to the light not flashing.
Anybody have any ideas? I would really like to get this to stop flashing.
Thanks in advance for any thoughts. Lets hear what your ideas could be....
Old Aug 3, 2010 | 07:55 AM
dkf's Avatar
dkf
An 05' truck will have the 5R110 (Torqshift) not the 4R100.
Old Aug 3, 2010 | 08:47 AM
Toyman's Avatar
Toyman
OOPS!! your right. Changed the title. Same issues different series trans.
Good call DKF, cool avatar by the way!!
Old Aug 3, 2010 | 09:27 AM
senix's Avatar
senix
keeping it fresh, maybe Mark will chime in. He was one of the engineers for it.
Old Aug 3, 2010 | 10:48 AM
Toyman's Avatar
Toyman
That would be awesome.....
Old Aug 3, 2010 | 08:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A solenoid can't cause a speed sensor code. It could be the speed sensor, but is most likely an intermittent open in the wiring between the PCM and the output speed sensor.
I've also seen codes like this from a defective alternator. A diode in the alternator fails and the alternator puts an AC signal on top of the +12V DC that it is supposed to output. This AC signal plays havoc with speed sensors.
Old Aug 4, 2010 | 09:25 AM
Toyman's Avatar
Toyman
the speed sensors have been replaced. I also just put an alterantor on the truck when we were in St Ignace for the car show. I know, great timing for that to go out.
I have messed with the wire harness down by the trans. I have removed and cleaned and doubled cheecked all the pins to make sure they had good contact. I also went ahead and called a dealer to see about the wire harness itself and found that they were nationally back ordered through the end of August (I called about a month ago), I have the harness from the transmission up on order. Is this where you think the wire may have an open?
I have been slowly trying to track this down since last winter. best part is for the last few days it hasn't been flashing and the truck actually feels right again.
Thanks for the help Mark. Let me know if that is the harness you were refering to. I can call and get the part number from my buddy at the Frod dealer to make sure I am getting the harness you are referring to.
Toyman
Old Aug 4, 2010 | 06:43 PM
Mark Kovalsky
The PCM is behind the parking brake pedal. The wiring between there and the transmission could have a wiring problem. I don't know how the harnesses are configured.
Old Aug 4, 2010 | 09:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
I've seen many "new" rebuilt alternators with bad diodes right out of the box. Quality Control is to spin them and see if they put out some voltage, so don't discount the alternator just because you just installed it.
Old Aug 4, 2010 | 09:22 PM
Toyman's Avatar
Toyman
Make sense on the alternator. But for 2 of them to act the exact same way.
I will check the harness behind the park brake lever. Ironically, I notice the issue when I mess around the break lever. When I took out the other tuner the light stopped flashing, and has just started to flash again....2 days later.
At least it might be isolated. I will take the kick panel off tomorrow after work and see what it looks like.
Thanks for the help and the suggestions......keep them coming.
Toyman
Old Aug 5, 2010 | 04:35 AM
Mark Kovalsky
My record is three alternators in a row right out of the box with bad diodes.
How do you know these are good without testing?
Old Aug 5, 2010 | 05:29 AM
senix's Avatar
senix
two alternators and two starters (nissian), 3 electric radiator fan motors on a buick...right out of the box.
Old Aug 5, 2010 | 06:26 AM
Toyman's Avatar
Toyman
sooo, how would I test the diodes in the alternator to know for sure.
Old Aug 5, 2010 | 06:29 AM
senix's Avatar
senix
Take it to autozone or napa and they can test it for you right on the truck.
Old Aug 5, 2010 | 07:36 AM
Toyman's Avatar
Toyman
A diode test can be done right on the truck? I will run over there on lunch and have it checked..
