injector issues
Old Aug 3, 2010 | 12:55 AM
crankytrucker's Avatar
crankytrucker
injector issues
Hey guys Im new to the site but have found some very hepful info here but now I am puzzeled and could use some direction. My truck was acting up idling up and down and then would sputter and smoke. I checked with my tuner and got P0282 and P0284 problems with injector 8. I cleared it put in some fresh fuel some conditioner and replaced both filters and had the mech check it with a real comp and they couldnt find anything and it was running fine. Took it home and thought try to drive it hard and see what happens and now I got a P0266 injector 2 code. Why am I suddenly gettting eratic and inconsistant codes. I heard blown hgs can throw false codes as well is this true? Could it be the ficm? Could it actually be bad injectors ? getting frustrated supposed to go on holidays with the trailer but could end up cancelling trip if problem not figured out soon. thanks for any help
Old Aug 3, 2010 | 01:38 AM
cartmanea's Avatar
cartmanea
FICM can cause goofy injector behavior. Check your FICM voltage, key on engine off, should be 48V. Do a search for the procedure.
Old Aug 3, 2010 | 11:08 AM
rickatic's Avatar
rickatic
Good advice from Cart... I would suggest if you do not have a fuel pressure gauge you should get one. The injectors on the 6.0 are fussy about fuel pressure, either too high or too low.
eddiedebb
Oct 9, 2013 10:03 AM
JCark
Nov 27, 2012 07:34 AM
bridge
2004 - 2008 F150
Sep 12, 2011 08:17 PM
goatz
13
Aug 13, 2009 10:06 AM
06powerstroke06
Feb 25, 2009 12:47 PM
