Anybody had this problem before?
Old Aug 2, 2010 | 03:42 PM
shark1979's Avatar
shark1979
my belt is rubbing on my lower radiator hose. it has never done this before. have any of you ever had the problem before, if so what did you do to fix it?
Old Aug 2, 2010 | 03:59 PM
BillyBob69's Avatar
BillyBob69
Hmmmm Belt rubbing on the lower hose. Maybe the Atkins diet can help!
Sorry couldn't resist.
Try loosening one end of the hose or both and giving it a twist to pull it away from the belt path. Then tighten it back up.
I haven't heard of this one tho. Seems the hose somehow moved. Shouldn't be hitting it at all.
Old Aug 2, 2010 | 04:00 PM
shark1979's Avatar
shark1979
forget i asked that question, i had a brain fart. belt was on wrong! problem solved.
Old Aug 2, 2010 | 04:01 PM
GreatWhite99's Avatar
GreatWhite99
Never had it happen before, but check your belt tensioner ,might be gettin weak causing it to hit, just a thought....
Old Aug 2, 2010 | 04:19 PM
Ponyboychris's Avatar
Ponyboychris
That would do it. Glad you got it figured out.
Old Aug 2, 2010 | 05:44 PM
farmdad's Avatar
farmdad
Don't ya just hate it when that happens????!!!!!! I'm sure others had that problem, just didn't fess up to it. I wouldn't either......
Old Aug 2, 2010 | 06:24 PM
Ponyboychris
My sticker on the header panel for the belt routing is illegible so I really have to pay attention when I take the belt off.
Old Aug 2, 2010 | 07:46 PM
Kwikkordead's Avatar
Kwikkordead
Does this help?
Old Aug 2, 2010 | 08:37 PM
Ponyboychris
Thanks Dan! I saved, printed and put it in the glovebox.
jbounds
Jan 26, 2012 05:13 PM
Chris Milne
New Member Introductions
Oct 28, 2008 04:39 PM
desygityaso
Nov 14, 2007 01:35 AM
18fan
Apr 8, 2004 11:43 AM
86ford
Apr 26, 2002 01:25 PM
