FUEL TANK
Old Apr 24, 2002 | 07:52 PM
86ford's Avatar
86ford
FUEL TANK
Replaced the sending unit on my fuel tank (single tank). Reinstalled the fuel tank and now when I fill up I have to pump the gas in sloooooow. Did I screw something up, never had that problem before? Thank You, Bill
Old Apr 24, 2002 | 09:49 PM
Franklin2's Avatar
Franklin2
FUEL TANK
My 1980 used to be like that till I went to replace my tank, and noticed the fill tube was actually two pipes. I noticed the small pipe inside had a holder and it had fallen out of place. When I put the new tank in, I made sure the small pipe was located correctly and the filling problem went away.
Old Apr 24, 2002 | 09:52 PM
IlllMikeIlll's Avatar
IlllMikeIlll
FUEL TANK
thats about what i was gunna say...but ive been kicked offline 5 times trying to reply... its easiest to take the whole big rubber hose off and fit the smaller tube into the small slot in the filler neck.. then pup the hose over the tube and clamp it back down trying to fit the small tube up the big one...takes a while
Old Apr 26, 2002 | 12:41 PM
Fordiod's Avatar
Fordiod
FUEL TANK
Make sure the main hose isn't kinked (even slightly). Mine was and that caused slooooo filling.
Old Apr 26, 2002 | 01:25 PM
Mil1ion's Avatar
Mil1ion
FUEL TANK
mike L
39
Nov 23, 2014 09:33 AM
tkisling
Dec 25, 2013 09:47 AM
664x4drvr
May 27, 2012 02:31 PM
Revmitchell
Jan 30, 2011 01:03 PM
Reptar360
Nov 1, 2004 07:21 PM
