fuel leaking
Old Jan 26, 2012 | 07:14 AM
jbounds's Avatar
jbounds
fuel leaking
Hey guys and gals I don't kniw if any of you had this problem before I have a e99 f350 7.3 I changed out my fuel filter because it was leaking out the drain tube and it fixed it last time now after changing it it is still leaking out and i don't know why has anyone had this issue before?
Old Jan 26, 2012 | 07:24 AM
mueckster's Avatar
mueckster
Sounds like you need to replace the o-rings on the drain valve. This is a common leak problem on the stock fuel bowl. Did you drain the bowl when replacing the filter? Sometimes opening and closing the valve reseats the o-rings on the barrel valve and is a temporary fix.
Old Jan 26, 2012 | 07:25 AM
Superduty ROCKS's Avatar
Superduty ROCKS
Go to dieselorings.com and order you a fuel bowl rebuild kit. Or at least the o rings for the drain valve.
Bob is great to work with, fast shipping, and great prices. Oh, and this will solve your leak
Old Jan 26, 2012 | 07:27 AM
riverrat41's Avatar
riverrat41
If it is leaking out the drain tube I bet you orings are shot.The ULSD does a number on old orings.Look here.You can get the orings from Bob.Great guy with fast shipping.
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Old Jan 26, 2012 | 04:32 PM
jbounds's Avatar
jbounds
Thanks a lot guys o rings ordered that's why i love this site great people and quick responsesi
Old Jan 26, 2012 | 05:13 PM
Tailgate77478's Avatar
Tailgate77478
If you don't go with an entire fuel bowl rebuild, two #202 viton o-rings work for the valve (which is the culprit 99% of the time).
george horner
Apr 1, 2012 09:39 PM
loner1
Oct 20, 2011 03:33 PM
rivrrunner
May 13, 2011 10:26 AM
Orezona
Dec 30, 2006 01:40 PM
troubledsol
29
Nov 30, 2005 11:28 PM
