Fuel filter location
Old Aug 1, 2010 | 05:06 PM
vls's Avatar
vls
'79 F250 400 C6 4WD Dual driver's side tanks. Engine almost dies going up steep hills, but runs fine if I let off the gas a bit. Is there another inline fuel filter besides the one on the 2bbl carb? I'm assuming that's the problem.
Old Aug 1, 2010 | 07:20 PM
cghstrojan08's Avatar
cghstrojan08
Usually there is one on the bottom of the fuel pump.
Old Aug 1, 2010 | 07:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There is a nylon mesh strainer on the fuel pickup in the tank
Old Aug 1, 2010 | 07:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, you might check the condition of ALL of the flexible fuel lines at the tanks, selector valve and fuel pump. These get hard and crack and can either fail internally blocking flow, or crack allowing the pump to suck air.
Old Aug 1, 2010 | 07:44 PM
cghstrojan08
We had a rubber fuel line on a '85 mercury just close in on itself cause it got so ate up. It would run but if you tried to take off or accelerate it wouldnt run.
Iaff113
Dec 12, 2014 08:37 PM
Scratcher
Jun 8, 2010 09:50 AM
DSMMH
Feb 24, 2010 01:16 PM
numocystic_10
16
Sep 29, 2008 07:08 PM
UGA33
Oct 15, 2006 11:41 AM
