S. California Chapter Join Chapter, Leader:
August All Topic Thread
Old Aug 2, 2010 | 08:12 AM
  #46
fire240's Avatar
fire240
morning socal.
Old Aug 2, 2010 | 08:38 AM
  #47
Snowbunny's Avatar
Snowbunny
Morning, Everybody!!
Old Aug 2, 2010 | 08:51 AM
  #48
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Hi Miss Liz...you keeping things spinning up on the farm?
We're ready for some Burgerville in around 5 weeks
  #49
67nukeford's Avatar
67nukeford
Veteran: Navy
Good morning SoCal!
Old Aug 2, 2010 | 09:14 AM
  #50
Sparx Macgyver's Avatar
Sparx Macgyver
Morning everybody! I'm up early! Woohoo! Hey Steve, Anthony. Hello Everybody elseI don't know by name yet!
Edit: Steve, I unbolted the front cross member, but it apears to be stuck. On the driverside of it, it is blocked by both the exaust at one side, and brake lines and wireing at the other. What the frak?
Old Aug 2, 2010 | 09:20 AM
  #51
SteveBricks
FTE Emeritus
Easier to drop the exhaust than it is to undo brake lines and have to bleed it.
Old Aug 2, 2010 | 09:32 AM
  #52
F354JOE's Avatar
F354JOE
Good morning all! Day two!
Old Aug 2, 2010 | 09:42 AM
  #53
Sparx Macgyver
I know that, I'm just getting irritated at all the crap I have to take off to get the trans out. God knows if I lose a bolt somewhere...
That's my goal for today. To at least get the trans OUT of the truck. then I can work on the rebuild.
Btw, how the eff do you get the spare tire off? I've got a flat, and no idea how to get the spare off. I tried un bolting it, but it just spins? Thinking back, my Dodge didn't have a spare...
Old Aug 2, 2010 | 09:44 AM
  #54
SteveBricks
FTE Emeritus
Sounds like the stud on the holder was replaced with a bolt at some point...you'll probably have to figure out a way to get something in there to hold it from the back side while you undo it.
Old Aug 2, 2010 | 09:53 AM
  #55
Sparx Macgyver
Maybe. Casue there's a loop looking bolt, and then the other far end has an actualy bolt on it, and i dunno if the middle has anyhitng ot not. i didn't look there.
Old Aug 2, 2010 | 09:58 AM
  #56
SteveBricks
FTE Emeritus
I'm pretty sure there's a speednut type of deal that the "loop looking bolt" screws into.
Old Aug 2, 2010 | 10:05 AM
  #57
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
72 F100 with the spare mounted under the bed to a T shaped bracket?
The long bolt on the left side is secured with a hex nut, but on the right side, the bolt is secured with a U shaped sheet metal nut that slips onto the frame rail.
The nut is secured within the sheet metal cover by tabs. The tabs rust out, the nut spins around and around and around.
Old Aug 2, 2010 | 10:12 AM
  #58
Snowbunny's Avatar
Snowbunny
Oh, Nummy!!! I'm buying!!! The onion rings are especially good this year!!!
Old Aug 2, 2010 | 10:13 AM
  #59
SpringerPop's Avatar
SpringerPop
Bill, I swear you've FORGOTTEN more that I'll ever know about these trucks, and I lovingly owned and cared for a '70 C/S for many years, and thought I knew it well....
This place is so lucky to have you here!
Pop
Old Aug 2, 2010 | 10:17 AM
  #60
SteveBricks
FTE Emeritus
I wanna Walla Walla
