2003 Explorer Jumpy Steering
Old Aug 4, 2010 | 03:20 PM
Ford7269's Avatar
Ford7269
Spoke to a FoMoCo Tech (No vested interest in the outcome of advice), pull the power steering belt off, take it around the block, quickly as there is no water pump spinning, and if you still have the same dead spots it the rack.....Its my rack............Of course
Old Aug 4, 2010 | 03:27 PM
bbdano's Avatar
bbdano
Check out the intermediate shaft joint on the steering. I have a 2005 Expedition. Sound like my problem. I took some WD-40, and with the engine running, carefully sprayed the joint while my son was in the vehicle turning the wheel from stop to stop. I really loaded it up. Bingo! no more hard/easy steering. Easy all the way. It will flare up from time to time, but I just doushe it up again.
Old Aug 4, 2010 | 05:16 PM
Ford7269's Avatar
Ford7269
Ok Thank you I will try that before I tear it down, Thanks
Old Aug 6, 2010 | 09:02 AM
Ford7269's Avatar
Ford7269
Wow that worked great, I used white lithium grease so it would stay longer. Thanks
Old Aug 6, 2010 | 08:12 PM
bbdano's Avatar
bbdano
Jump steering
Just doing my part...glad I could help.
dano
avking2508
Apr 3, 2017 07:01 AM
heaffie
Jun 5, 2016 11:21 AM
the_hetz
May 10, 2016 09:19 AM
bakerbuilttracks
Aug 16, 2015 07:40 AM
lstr81
Escape & Escape Hybrid
Jun 23, 2015 07:18 AM
