Jumpy Tach needle
Old May 6, 2016 | 02:53 PM
the_hetz's Avatar
the_hetz
Jumpy Tach needle
I have an autometer tach on my steering column. I've been trying to figure out why it is jumpy. At one point, I thought I had it narrowed down to a bad ground...played around with it a bit and it was working fine. Once I put the dash back in and drove the pickup, it was jumping again.
FINALLY, I figured out that it begins jumping when the gauge cluster is plugged in. I can't seem to figure out why. I have 2 wires spliced to the tach on the plug. One is for power, and the other for lights (I believe this is correct, but will check). Since the wires are spliced in on the plug side, they are connected regardless of whether the plug is plugged into the back of the cluster. This has me a bit confused...I don't understand why plugging it in would affect anything if these wires are always connected.
It has got to be something to do with interference coming from the dash once plugged in.
Thoughts?
Old May 6, 2016 | 06:22 PM
Canus's Avatar
Canus
If you are trying to power the tach from the gauge cluster you are possibly having your power go through the ICM which provides the gauges with a "pulsed" current. You need to get your power from a 12 volt "hot when on" source.
Old May 8, 2016 | 01:58 PM
ZarK-eh's Avatar
ZarK-eh
Which wires did you splice into?
Maybe post a photo of it to help identify, I can check a schematic to verify.
Old May 9, 2016 | 09:13 AM
the_hetz's Avatar
the_hetz
The power doesn't come from the cluster itself, it comes from the plug that goes into the cluster and works fine until it is plugged in. I've attached a simplified diagram that I just made in paintbrush to show what I'm saying. I will pull the cluster out again in the next couple days to let you know the exact PINs used, but from what I can tell the power should be clean.
The ground is well secured.
BTW, this is on a 74 F250. I see that I didn't mention the vehicle details.
Old May 9, 2016 | 11:49 AM
HoustonDave's Avatar
HoustonDave
Just a guess but I would speculate that the dash cluster ground(s) may be somewhat flaky. Not enough to affect the dash but enough that the extra load might be just over what they can handle? I'm not an electrical guy but it sounds logical.
Old May 9, 2016 | 12:21 PM
Justin73supercamper's Avatar
Justin73supercamper
I have a dumb thought. But I noticed the same thing on my volt gauge. Does it bounce when the turn signal is on? I know it sounds dumb
Old May 9, 2016 | 03:37 PM
HIO Silver's Avatar
HIO Silver
Separate tach and other gauges' grounds from the instrument cluster grounds...
And find a different power source for the tach.
Old May 10, 2016 | 09:19 AM
the_hetz's Avatar
the_hetz
It bounces all the time but does bounce worse when the turn signal is on. It is a mild difference, but it is noticeable.
The tach ground is going directly to the body, if I recall. I will double check that and where the + wire actually comes from and go from there.
Thanks
'86 F150
Jun 25, 2013 03:51 AM
tempest411
Nov 21, 2012 11:33 AM
cobrasjj
Jan 28, 2008 07:44 AM
khadma
1997 - 2003 F150
Jul 14, 2007 07:11 AM
88blkranger
1983 - 2012 Ranger & B-Series
Aug 6, 2004 10:49 AM
