Won't start help!!
Old Jul 29, 2010 | 03:07 PM
trigeek22's Avatar
trigeek22
Won't start help!!
I've got a 1984 F-150 4.9L 300. Installed a new starter, was told since I did that, put in a new starter solenoid also. Have had problems since then. First one I must have put the positive and negative backwards drained the battery. Second one I bought must have been a bad one, it just clunked when I tried to start it. Now my third one I have power to the lights, radio, etc. But the engine won't turn over. I was told to try the jumping method to see if it will start. I could really use some advice. Thanks everyone. Dani
Old Jul 29, 2010 | 09:22 PM
leavy20's Avatar
leavy20
so you have a brand new starter, solenoid, and battery? are your terminals tight, aswell as all your other wiring for the starter. i had a extreme starting issues on both my trucks this last year, 1st was caused by bad terminals(replaced starter and solenoid, before i figured that out) 2nd was something in the wiring(i undid all wires for starter cleaned them up then reinstalled)
Old Jul 29, 2010 | 09:31 PM
DreadyDiggs's Avatar
DreadyDiggs
leavy's on point. Here's what I ended up doing...
New starters or Remans?
My starter died (would thrust forward but wouldn't spin), had to pop the clutch to get it home. Napa suggested a starter and starter solenoid. First starter was bad. Benched tested it with a batter and jumper cables. Spun but wouldn't thrust forward.
Second starter's been good since I installed it, better stay that way.
Just be very sure that everything on the solenoid is the way it was before all of this. Also yea, bench testing your starters with a battery and cables works fine, watch out for sparks.
If the truck is manual pop the clutch to see if it will start. Take the starter off and yea bench test it.
smashclash
47
May 11, 2023 09:04 PM
granny_rocket
30
Jun 28, 2012 07:47 PM
praisethelowered17
Oct 17, 2011 06:29 PM
Knightmayre
Jul 18, 2004 05:25 PM
DSalmon
Jan 24, 2004 09:56 PM
