Engine won't start
Old Jan 18, 2004 | 12:30 AM
DSalmon's Avatar
DSalmon
Angry 1973 Ford F-350 won't start HELP PLEASE!!
Okay any help you can give me would be great! .. we are about to take our truck to a mechanic because we can't figure this out. Our 1973 Ford F-350 won't start it turns over but will not start .. We changed the distriburator , had the starter tested and it was fine .. but now we have no idea .. We just had two head gaskets replaced and then we drove it home and it kept dying .. now it won't even start .. after we put the new distribuator on it started for a sec then died and hasn' t started since .. It will fire up but that is it .. we tried to jump it and everything .. the choke isn't stuck we checked that .. any ideas !!! PLEASE HELP !!
Old Jan 18, 2004 | 12:46 AM
Matts72's Avatar
Matts72
The ignition module is a fairly common culprit, its the silver box on the drivers side, take it to a parts store and they should test it for free.
I would also suspect that your timing has jumped one or more teeth, or broken its chain all together.
The coil can be a culprit too, but its not so common to just give out and not start up later.
Welcome to FTE, please be sure to include all pertinent information, in this case, what motor it is.
Old Jan 18, 2004 | 05:17 AM
Alphy's's Avatar
Alphy's
1973 didn't have ignition modules,
Old Jan 18, 2004 | 05:51 AM
lastchance's Avatar
lastchance
Might be easiest to start with the fuel. Take the air cleaner off and look down the throat of the carb. As you push the throttle linkage back you should see a little stream of gas spray into the carb. Then at least you know if you have fuel. You said you jumped it...is it cranking over ok? Take the wire that goes from the coil to the center of the distributor cap and place it somewhere close to the block or intake and have someone crank it to make sure you have good spark. I would guess if you replaced the distributor there is a chance you have the spark plug wires on wrong, or it is just out of time. Try roatating the distributor slightly...maybe even have someone crank it while you are turning it.
Old Jan 18, 2004 | 01:07 PM
73Custom's Avatar
73Custom
Re: 1973 Ford F-350 won't start HELP PLEASE!!
Originally posted by DSalmon
We just had two head gaskets replaced and then we drove it home and it kept dying .. now it won't even start.
Was this done by a professional mechanic? Did it run this way when you took it to him? If not, then take it back - before you change things. It obviously wasn't right on the drive home.
Marty
Old Jan 18, 2004 | 04:53 PM
Colo79Ford's Avatar
Colo79Ford
Did you check a new fuel filter out??
Old Jan 18, 2004 | 09:52 PM
DJChunter's Avatar
DJChunter
My 75 did that when the floats in my junk holley were stuck.. got out and beat it to hell with the hammers and starts just fine now..
Dave
Old Jan 20, 2004 | 10:07 PM
coorslightbeer's Avatar
coorslightbeer
4wd Low
when i first got my licnese i got to drive a 72 f250 to school and on my first day of driving to school my truck did the same kind of thing. it turned out to be the condinser, since you do not have electronic ignition you must have points and condinser, but if you changed them out when you replaced the distributer thien it is more than likly the coil or its connections.
good luck
Old Jan 20, 2004 | 10:15 PM
Mil1ion's Avatar
Mil1ion
Hmmm...
Distributor
Condensor
How about... the points have changed their gap?
Timing ?
Coil ?
Ignition circuit ?
Old Jan 20, 2004 | 10:23 PM
coorslightbeer
4wd Low
hey i know a few things about old trucks, that dosent mean i can spell.
Old Jan 20, 2004 | 11:20 PM
Matts72's Avatar
Matts72
wow thats the first time somebody hasn't taken spelling suggestions badly!
By the way, coorslightbeer, try http://www.spellcheck.net
Old Jan 24, 2004 | 09:56 PM
fordpilot's Avatar
fordpilot
D You might check a plugged exhaust system or plugged cat convertor if'n you got one. Good Luck!
reeder65
Jan 13, 2012 08:34 PM
FORDTRUCKS79
Jan 27, 2011 07:01 PM
54ford
15
Feb 18, 2008 09:49 PM
signguys
46
Jan 11, 2007 07:23 AM
jdodgen
Electrical Systems/Wiring
Jul 19, 2003 02:22 PM
