I own a 1994 F250 IDI, I put a 6" lift and a solid axle swap and 37" tires, I will post some pics later, but I am leaking brake fluid, at a fairly slow rate. I have spent hours trying to find the leak, I have followed the lines right from the master cylinder to every wheel, and along the frame the entire way and there is no visible leaks. I have the truck super clean and in the shop in an attempt to find the leak, but in 2 days of sitting there is not a drop of fluid on the floor, yet my brake fluid is slowly draining. I have bled all the lines at the wheels, with no air coming out, yet the brake pedal will still fully compress to the floor, indicating a loss of pressure. Right now I am going to take my rear drums off to see if it is leaking inside, other then that I am at a loss of where this fluid is going, has anyone else had this happen to them? Any ideas?
it is losing fluid very slowly while sitting, as the resevoir is going down. While pumping the brakes I was under the truck inspecting all the lines, I forgot to add that in the previous post, but it was also losing fluid at a faster rate, I will put paper towels along all the fittings, master cylinder and such.
thanks.
My step-father's car would smoke when you hit the brakes. Booster was drawing fluid in, and sending it right into the intake..Replaced mastercylinder, all good now.
if the master cylinder is gone if I pull the master cylinder, I am to understand there is a rod/plunger in there with a snap ring before it? if I remove this I should be able to tell if the cylinder is gone? If it is drawing brake fluid in the vacuum line then the booster is gone?
theres is fluid leaking from the master cylinder into the booster where it attaches, so the seals must be gone on the plunger. I have pulled the master cylinder apart and the inside looks fine. Can i just replace the seals or do I have to get a whole new master cylinder? The truck sits during winters as I live in Northern Canada and I hate rust!, could the sitting during the winters be the culprit for the seals going?
You should be able to get a repair kit for around $30.00 which, if it was me, is the way I would go.
Try to clean out any brake fluid from the brake booster as best you can as it can cause booster failure.
The only thing with the repair kits is making sure the cylinder bore is free of corrosion. Altho I have never rebuilt them, (or wheel cylinders for that matter,) I would see no problem using the kit. Be sure to bench bleed it before installing the M/C...
I had some extended brake lines sitting around and decided to install them, as well as some brake tube. I am replacing the line from the front driver side hose in the fender that goes to the master cylinder, do I have to rebend the line in the spiral? if so, why can't I just have a line running straight down?
Old mechanics would probably tell you the spiral is for flex, or for extra line in case of needing a repair, or for ease of removing the line and replacing when you need to replace the M/C so you dont cross-thread the brake line. I personally have adopted all those ideas many times. (Blame it on an old mechanic...)
A straight line is ok, just make sure there is sufficient length for flex, and ease of installing the line so as not to cross-thread, and keep it away from the exhaust. Double-Flare is the Rule. Single flare is dangerous and illegal.
Thanks for all the help. After installing the new master cylinder and my new lines I hopped in the truck and started it and found that the brake pedal was still losing pressure!!! There is only one possible thing that I think it could be, and that is the ABS module. I ended up talking to one of the technicians at the local ford dealership and he informed me that this is a very common problem for these trucks. I would have to pay 350$ and wait atleast 10 days to get a new one, so my question is can i just delete this from the system?.
I am to understand that it is not a true abs system, and only relieves pressure to the rear brakes by relaying it through that module? I am ok with losing the rear abs, so can i just run a line in place of the module? what about the wiring? and do I have to install a proportional valve? or is there already one in place? I am guessing that one would be required to stop the same amount of pressure going to the back as the front, as the back brakes would lock up well before the front?
You are right it is not ABS but rear brake system only (RABS).
There is an easy test. IF you look at the RABS module you will see a big hex bung on the end of it. Unscrew that bung (under spring pressure all the way) and remove the spring from inside the chamber (no fluid will come out). Replace the bung and pump the pedal a few times to fill the chamber with fluid. See if that solves the sinking pedal. If it does then you can just leave it like that or bypass the module with a short length of hard line. If it does not solve the problem then replace the spring and look else where.
I am pretty much at the point of throwing tools around the shop. I removed the abs module and when i turn the truck on the brakes still sink to the floor. I have replaced all the brake lines, new master cylinder, new rear wheel cylinders, the calipers where replaced about 6 months ago, and the all new rear brake shoes and drums. I have plugged the lines going from the master cylinder, and it holds when the truck is running. I then plugged only the line going to the rear and bled the front brakes. When running the pedal compresses to the floor with only the front brakes attached. I am going to plug the front and open the rear to see if the pedal compresses in an attempt to isolate the problem. Does anyone have any idea what is going on? I have adjusted the rear brakes and put the drum on properly as well as bled the system numerous times for extended periods of time. I also bench bled the master cylinder properly. I am stumped as to what the problem is. Could it be a caliper?
