STARTER WONT START
Old Oct 15, 2011 | 12:07 PM
praisethelowered17's Avatar
praisethelowered17
STARTER WONT START
so i am trying to replace the starter in my 62 f100 pickup. the starter solenoid that was in there was working
but i had one that fit and decided to put it in. I've connected the wires to the new solenoid the same way the old
one was connected. it still won't even try, and when i tried to connect the old one back in, it doesn't work either now. what sould i do?
Old Oct 15, 2011 | 02:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
one was connected. it still won't even try, and when i tried to connect the old one back in, it doesn't work either now. what should i do?
The Bendix drive used on these trucks has a large coil spring incorporated with it.
If the spring breaks, the starter motor will just spin, because the drive cannot mesh with the teeth on the flywheel.
Old Oct 16, 2011 | 02:37 AM
praisethelowered17
thanks! this helps alot
Old Oct 16, 2011 | 08:56 AM
huckdeuceman's Avatar
huckdeuceman
Is the starter spinning and just not catching the flywheel or is it not doing anything?
is it engaging and not turning the motor over? if it is engaging you might have a bad
winding?...
Old Oct 16, 2011 | 10:07 AM
Broomfieldbum's Avatar
Broomfieldbum
Are you sure your flywheel is in good condition? If you have teeth missing you could just have your engine in a bad spot in the flywheel, and therefore it won't work.
Old Oct 16, 2011 | 11:18 PM
praisethelowered17
no its not doing anything, it has juice from the battery but when i turn the ignition key, the lights work and the radio works, but it doesn't spin or engage the engine, and when i tried to put the working old one back in and it doesn't do anything now, even though its wired exactly the same it was when it was working...
Old Oct 17, 2011 | 12:57 AM
66CustomCab's Avatar
66CustomCab
Did you check the wires & the ground to the block for breaks?
Old Oct 17, 2011 | 07:21 AM
Broomfieldbum
Bypass the solenoid, and see if that cranks. Just take a large pair of channel locks or a large gauge wire, and connect the battery directly to the cable going to the starter. If that does it then you have a bad solenoid.
Old Oct 17, 2011 | 10:34 AM
huckdeuceman
You might have puchased a bad ''Starter''? even tho it's new doesn't mean it's good?
if you have 12 volts going to it, it should at least spin even if the bendix don't push it in
to the flywheel!..last resort take it off and take it back to where you got it and let them
bench test it!...
Old Oct 17, 2011 | 01:38 PM
praisethelowered17
when i connect both bolts on the solenoid with two positive ends of jumper cables it will start the truck but it just doesn't work with the key.
Old Oct 17, 2011 | 01:41 PM
Confederate Diesel's Avatar
Confederate Diesel
Switch the two small wires around.
Old Oct 17, 2011 | 06:29 PM
praisethelowered17
i'll go try that
williej70
Jan 16, 2017 09:06 AM
rpaxton939
Apr 9, 2014 08:15 PM
fish-albuq
Dec 30, 2009 04:23 PM
thumper869
Oct 27, 2009 01:17 AM
slyde
Feb 6, 2005 11:09 AM
