External Oil Coolers
Old Jul 27, 2010 | 09:51 PM
scottman70's Avatar
scottman70
Who is using an external oil cooler on their 6.0? What EOT/ECT temp differential are you seeing idling, driving and towing? Is your fan running more often than with the oem oil cooler?
Old Jul 28, 2010 | 06:07 AM
Kjewer1's Avatar
Kjewer1
Does the temp spread even matter with an external cooler? Just curious. I would think it doesn't, since the temp spread is no longer an indicator of internal oil cooler health, but external oil cooler efficiency. Oil temps would then just be looked at as an absolute value. Coolant temps should still be regulated as usual, and maybe be a little better without the heat load from the oil cooler applied to the coolant, letting the fan run less often. Note that I have no direct experience with this situation and can't answer your question, just thinking out loud.
Old Jul 28, 2010 | 06:37 AM
bismic's Avatar
bismic
The fan may or may not run less often. The PCM is not just looking at coolant temperature for the fan to operate.
No doubt, there will be less heat load on the coolant. I know a few folks on other forums using the external cooler. I will go check who specifically it is and let you know.
BTW - Check out the thread "testing". An International tech (adamtheman16) states that the Internationals (using Texaco ELC coolant) just dont see oil cooler failures.
DawnPatrol
Aug 31, 2013 05:06 AM
tjustice
Jun 6, 2013 04:15 PM
DieselVol
Feb 15, 2013 05:40 PM
oldbird1965
Nov 19, 2008 08:24 PM
TreeFarmer05
Dec 22, 2005 05:19 PM
