external oil cooler
Old Nov 18, 2008 | 10:26 PM
oldbird1965's Avatar
oldbird1965
external oil cooler
Besides the stock oil cooler, is anybody running a external (extra) oil cooler? Just curious!
Old Nov 19, 2008 | 06:45 AM
tjbeggs's Avatar
tjbeggs
Not that I know of. If you did though it could hurt your mileage and efficiency. Diesels like to be hot. If you cool them down you make it harder for them to burn the fuel. That why the 203 thermostat is a good mod. Gets more heat in the engine.
Old Nov 19, 2008 | 09:25 AM
MADVAN's Avatar
MADVAN
X2 with Tj.
I have a cooler and fan with manual bypass.
The only time its used is in summer running on the beach
in 4X4 low. Otherwise i have found no need for it.
Bill
Old Nov 19, 2008 | 11:26 AM
rockitdog's Avatar
rockitdog
"High oil temperature in excess of 240°F (115°C) will break down petroleum oils and cause oxidation, which in turn forms deposits, varnish and increases wear.
Low oil temperatures will cause formation of sludge, which can block oil passages."
Since the oil coolers on our truck's keep the engine oil regulated to the same temperature of the coolant you should be just fine unless you reach an overheat condition.
Old Nov 19, 2008 | 08:24 PM
oldbird1965
Is this true with synthetic engine oil also or can it get hotter then dino without breaking down? Thanks PS MadVan, trans so far OK, 600 miles, 1000 to go!
DawnPatrol
Aug 31, 2013 05:06 AM
tjustice
Jun 6, 2013 04:15 PM
DieselVol
Feb 15, 2013 05:40 PM
scottman70
Jul 28, 2010 06:37 AM
TreeFarmer05
Dec 22, 2005 05:19 PM
