Trans shifting great now
Old Jul 26, 2010 | 12:25 PM
jt371's Avatar
jt371
______
Had a problem with my trans with it holding in gear and shift flair. Where it would rev up between 3 and OD. Called Brian at BTS and he gave me a couple things to look at with scan tool. Checked everything he said and it seemed to be shifting as the trans was told to shift. So it was not a problem with the trans but something was affecting the shifts. Found a post on here about the EBP sensor causing this. I monitored the sensor with the scan tool and found that to was sending almost a full 5V to the computer telling it was 53 psi backpressure. I removed the sensor, cleaned it and tested it with it out of the tube, still the same reading. Unplugged it and it would go into default with 43 psi and 0v. Drove it with the sensor unplugged and it shifted as it should and no more shift flair. Found a new sensor on ebay $25 shipped. went to clean the tube before i install the new sensor and found tube had holes in it. Removed tube lastnight to see what I needed to make my own. Happen to find the correct size (5/16) and length just laying around the shop at home. Bent it to match the original, cut the ends off the old one, flaired the ends and installed. Started truck this morning and now the EBP valve worked and monitored the EBP sensor with the scan tool on the way to work this morning. Everything is working great now.
Glad I found that post about EBP sensor messing with the shifting.
Old Jul 26, 2010 | 01:29 PM
overthehillbill's Avatar
overthehillbill
Gotta love a happy ending, what a great site.
Old Jul 26, 2010 | 10:27 PM
gradyc's Avatar
gradyc
wellhead
Great job on fixing your tranny problem. Man that was quick!!
Old Jul 26, 2010 | 10:36 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Man, that is very interesting to say the least.
Old Jul 27, 2010 | 10:48 AM
fordboy2's Avatar
fordboy2
can you link the thread about the ebp sensor
Old Jul 27, 2010 | 11:02 AM
jt371's Avatar
jt371
______
try this.......https://www.ford-trucks.com/forums/9...ensor-bad.html
Old Jul 27, 2010 | 11:06 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
cutthroatxxx
Sep 24, 2014 04:55 PM
78fordman
Jul 14, 2014 11:20 PM
Shake-N-Bake
30
Jun 2, 2012 02:11 PM
adamzelazowski
Nov 25, 2008 05:19 AM
ernesteugene
70
May 18, 2007 10:28 PM
