performance HPOP 's ?
Old Jul 14, 2010 | 10:09 PM
Barndon's Avatar
Barndon
i'm looking into buying a new HPOP. too many problems with my stock one. reckon she's pretty old now. i'm looking for one that will be able to hold the power i'll eventually be putting in the truck , so i don't by one now, and later find out i'll need another one. however as usual i'm looking for a reasonable price in them. in addition do they come with a new resevior ? or is it just the pump ? thanks for the help.
Old Jul 14, 2010 | 10:24 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Few things; are you throwing codes, having leaking issues, or very poor performance? Have you datalogged to see your pressures? Are you running a tuner or chip? What issues are you seeing?
Old Jul 14, 2010 | 10:36 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by Barndon
i'm looking into buying a new HPOP.... i'm looking for one that will be able to hold the power i'll eventually be putting in the truck , so i don't by one now, and later find out i'll need another one.
What kind of power are you looking at? With hybrids you do not need the biggest baddest pump though they make even those better. A healthy stock pump can power hybrids past 400 with the right setup. What is your goal?
Old Jul 17, 2010 | 02:12 PM
Barndon's Avatar
Barndon
well i have a leak on the in serviceable plug. took it in the get fixed, replaced all the seals and gaskets and still have the leak. they charged me an arm and a leg for it. in addition i dun stripped the level-check plug on top of the reservoir due to always having to refill the reservoir with more oil when i don't drive it for bout a week. anyhow i'm tired of dealing with it and dragging oil everywhere so i figure by getting something other than stock I won't have no problems again, regardless of what i put into the truck. as far as goals i think if i ever reached 400 that would be more than enough. i was thinking along the lines of either stage 1's or hybrids. and eventually a dp tuner. allz i have dun right now is a straight pipe. muffler delete.
Old Jul 17, 2010 | 02:30 PM
kupaa's Avatar
kupaa
i have a modded pump from terminator. fix the oil leak and did his magic for 100.00
Old Jul 17, 2010 | 07:43 PM
brownie83's Avatar
brownie83
i did the same thing...sent a pumpto joey at terminator and he sent bad a fixed modded one. it totally worth $100...try that first...good luck
Old Jul 17, 2010 | 09:11 PM
hucka1a's Avatar
hucka1a
Another happy Terminator customer right here.
Old Jul 17, 2010 | 10:20 PM
Tenn01PSD350
Anybody have any before and after ICP logs they would like to share?
Old Jul 17, 2010 | 10:23 PM
Stewart_H's Avatar
Stewart_H
Just after, sorry. I ordered my AE after sending my HPOP to Joey for modding.
Stewart
Old Jul 17, 2010 | 10:34 PM
beanhead6D5's Avatar
beanhead6D5
I will have some next weekend,Mike!
I am going from my stock pmp to Joey's moded 17* pump.
Old Jul 17, 2010 | 10:43 PM
Tenn01PSD350
Good deal. I am sure they will be improved, just curious by how much.
Old Jul 17, 2010 | 10:50 PM
hucka1a's Avatar
hucka1a
I do, but I don't know how to upload excel files.
Old Jul 17, 2010 | 10:57 PM
beanhead6D5
I'm just going to draw the chart out with markers on my screen.
Huck I'm in the same boat.Some times my putter hates me.
Old Jul 17, 2010 | 10:59 PM
Barndon's Avatar
Barndon
sounds good however i only have this truck as my single form of transportation. any ideas on how to resolve that issue ?
Old Jul 17, 2010 | 11:05 PM
Barndon's Avatar
Barndon
in addition, anyone have a layout, or blue print or instructions on how to properly remove the HPOP ? thanks
