Tranny problem EBP SENSOR BAD
Old Jul 13, 2010 | 02:50 PM
rgarcia1104's Avatar
rgarcia1104
My 2000 f350 7.3,seems to have a tranny problem, it hard shifts between 2nd and 3rd gear. The shop told me the EBP sensor is bad. Can that be causing the problem? Just bought this truck, I have already replaced the alternator and the VSS sensor. They both were shot.
O y R
Old Jul 13, 2010 | 03:32 PM
DieselCamper01's Avatar
DieselCamper01
Hey there you are! Not so bad on the thread starting huh?
I don't see how that sensor could cause a tranny issue but i am no expert either. Hopefully someone more knowledgeable chimes in soon. And welcome again to FTE
Any idea how old the fluin in the trans is? Look and smell ok?
Old Jul 13, 2010 | 05:21 PM
rgarcia1104
tranny hard shift roblem beween 2nd n 3rd
fluid looks n smells burnt, It had been stopped for months and I'm a little afraid to flush it, I dont want to kill my tranny... Do you know of any other site where I can research this problem?
O R C DR B
Old Jul 13, 2010 | 05:45 PM
tdpower's Avatar
tdpower
Welcome to the site! If your fluid smells burnt you probably already shortened the life of the transmission. I would go ahead and flush it. You can click on guzzle maintenance site in my signature and he has a write up on cleaning the ebp sensor. You also should consider upgrading your transmission cooler so the fluid does not get so hot.
Old Jul 13, 2010 | 10:03 PM
DieselCamper01
Grant is correct on all counts. Go ahead and change that fluid. It won't cure any wear issues but it will delay any future failures. Guzzle has some great writups
Old Jul 14, 2010 | 12:24 PM
rgarcia1104
Thank you both. I will follow your recommendation. Do you think the EBP sensor is causing a delay on my PCM? Could that be why my transmissions has a hard shift? Is there anything else you recommend to resolve this issue?
Old Jul 14, 2010 | 01:06 PM
DieselCamper01
You may want to join your Texas chapter of FTE and see if someone near you
can scan your truck for stored codes to see if that points you in a particular direction. It is "possible" that the EBP sensor is causing a slight hiccup but I don't think that it is likely.
Old Jul 14, 2010 | 06:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first rule in fixing ANY transmission problem is to ALWAYS fix the engine problems. Fix the EBP problem and chances are the transmission will be fixed, too.
Old Jul 14, 2010 | 07:25 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The PCM uses exhaust backpressure for torque calculations.......
Torque calculations are used for a lot of transmission functions.
Old Jul 14, 2010 | 09:56 PM
rgarcia1104
Thanks to everyone for the advise, I got the EBP tube coming out of the exhaust ordered, it was old and corroded. Hopefully that will fix my problem... I will keep you all updated.
Jay- Thanks for helping me through FTE....
R O C DR A
Old Jul 14, 2010 | 10:12 PM
frdf250's Avatar
frdf250
this might be a little off topic, but just curious, if the exbp sensor helps for torque calculations, what happens to all the guys, including me that did the sensor delete..im not trying to say your wrong, just really curious becuase if so i will go out and reconnect the line.
Old Jul 14, 2010 | 10:19 PM
DieselCamper01
R O C DR A
More than glad to help. I hope the sensor issue fixes the trans issue too. I Have never heard of that connection before. Curious too if it solves your issues. Please post back when you get the new tube on.
And I sure would not second guess Mark. He knows his stuff
What does ROCDRA stand for?
Old Jul 14, 2010 | 10:35 PM
bama29fan's Avatar
bama29fan
you deleted the EBP valve not the sensor.
Old Jul 15, 2010 | 06:04 AM
frdf250's Avatar
frdf250
no i deleted the sensor, i did delete the ebpv too. however in the front of the engine, i got a npt fitting cap and plugged it. no codes.
Old Jul 15, 2010 | 11:23 AM
bama29fan's Avatar
bama29fan
cool....i didnt know you could delete the sensor also...my bad
