door chime
Old Jul 26, 2010 | 12:19 PM
tralfamadorian's Avatar
tralfamadorian
door chime
my door chime has been going off for no particular reason. i don't really see a need to have it, what is the easiest way for me to delete it? where is the actual buzzer located? can i just rip it out and top the wires?
Old Jul 26, 2010 | 01:56 PM
nstueve's Avatar
nstueve
the door jam button is probably contacting even when the door is closed. you can pull it and clean with electrical cleaner or what i did was disconnect the wires at the button and use the head light **** to turn on the interior dome light...
Keep in mind that electrical cleaner is specially formulated so you don't make the plastic brittle... carb, engine and other cleaners will make all your plastic pieces brittle and they will break way easier once that stuff has been used on them...
Old Jul 26, 2010 | 02:37 PM
Lonzo's Avatar
Lonzo
On my '95, If I don't turn the key all the way to off, it will buzz after key is out (switch worn out). I don't know what year your truck is, but I remember on my '84 (or maybe my '81), I carefully pried the buzzer off a circuit board. It was soldered on there. I'm leaving the buzzer on this truck, as my memory isn't what it was.
Old Jul 26, 2010 | 02:56 PM
TexasGuy001's Avatar
TexasGuy001
I had that problem when my ignition lock cylinder was worn out. It would sometimes not chime when the door was open and would randomly chime while driving.
Old Jul 26, 2010 | 03:46 PM
jas88's Avatar
jas88
You don't say what year you have but on my '91 it is up under the dash just over the top of where your foot rests on the accelerator pedal.
Old Jul 26, 2010 | 03:57 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
The chime will go bad after time and can go off intermittently. It is a small black box under the drivers side of the dash just above and to the right of the gas petal. Just unplug it and the problem is solved. It could not be easier or more peaceful when it is gone. I certainly dont miss mine.
Old Jul 27, 2010 | 12:09 PM
tralfamadorian
thanks guys. i've got a 94 f250 to clarify... it might be the ignition switch, because it does seem kind of worn. my dome light tends to randomly come on when i go over bumps in the road, so i'm thinking some kind of short? I will get under there and try to find it today, i just don't want to pull the wrong thing out haha!
Old Jul 27, 2010 | 01:22 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Adjust the throw of your door switch.
Old Sep 19, 2010 | 02:37 AM
fordman41291's Avatar
fordman41291
Can you replace the "buzzer" with a chime? I would rather here a chime than a buzz...
Thanks in Advance
Pvt. Klein
bigcountry1009
Nov 13, 2014 08:07 AM
bobfordtrucks
1983 - 2012 Ranger & B-Series
Aug 24, 2014 09:54 AM
rocky3539
2004 - 2008 F150
May 17, 2008 10:23 AM
scummings62
Apr 13, 2008 12:58 AM
truckalpers
1997 - 2003 F150
Nov 2, 2005 03:00 PM
