Sponsored by: Auxito
door chime problems
Old Oct 26, 2005 | 05:26 PM
truckalpers's Avatar
truckalpers
door chime problems
My truck just recently started having this little problem. When I turn off the truck, and remove the key, the door chime keeps on dinging when the door is open. No key, no lights on, nothing. It's not the accelerated chime like when you leave your lights on, just the normal chime that should only happen when the door is open with the key in the ignition. Any ideas?
Old Oct 27, 2005 | 03:21 AM
dansegroves's Avatar
dansegroves
is your ignition tumbler worn out? my wife's 94 gt does the same thing and you can turn the tumbler with out the key and actually turn it 180 out of line to where you can't put the key in.
Old Oct 27, 2005 | 09:46 AM
truckalpers
I cannot turn the tumbler without the key in it. Anymore info?
Old Oct 27, 2005 | 11:13 AM
basecamp's Avatar
basecamp
Does your interior light stay on also? Fords are known for the switch in the door sticking. You can spray a cleaner like WD- 40 or the likes,in the lock mechanism in the door and open and close it and wipe it out as good as you can and that usually solves it for a year or so. Then dirt and grime build up again so just do it again.
Old Oct 27, 2005 | 02:36 PM
peppermrj's Avatar
peppermrj
My 98 is doing the same thing. No lights but the chime drives me nuts. Where in the door is the switch?
Old Oct 27, 2005 | 02:39 PM
basecamp's Avatar
basecamp
It is behind the actual locking mechanism in the door. You can't see it because it is kindof behind all the latch.
Old Oct 27, 2005 | 02:41 PM
peppermrj's Avatar
peppermrj
Cool thanxs. WD here I come.
Old Oct 27, 2005 | 02:48 PM
truckalpers
Yeah, I've done that trick several times on my last two fords, a 98 and an 01, but this one is different becasue the light doesn't stay on, just the dinger. It's starting to **** me off.
Old Oct 28, 2005 | 11:57 AM
truckalpers
OK guys, I tore into it last night. On the inside end of the tumbler, there is a little clip with a metal contact and a wire running up under the dash. I accidentally pulled that little clip out, and the dinging stopped. When I touched it back to the tumbler, the dinging started, key or no key. So I figured out where this thing went, bent it back to what I thought was correct, and put it all back together. No more keyless dinging. However, now my steering wheel doesn't seem to lock when I take the key out. FIxed one problem started another. Anyone got any info on the steering wheel lock?
Old Oct 28, 2005 | 11:59 PM
7700Rob's Avatar
7700Rob
Does the clip push the lock rod too?
Old Oct 29, 2005 | 04:50 PM
truckalpers
Not real clear on that, I'm not sure where the push rod is, but it seems like it would be hard for this clip to push anything, it's really small, looks like it was designed only to make a contact.
Old Nov 2, 2005 | 12:12 PM
storm96's Avatar
storm96
if any one finds a permanet fix for this problem please help us all out and post it cause my 97 F150 does the same thing only the door chime nothing else !!! it really pisses me off when hunting and then there goes my prey damn it !!!! help me fast hunting season is here again in the north !!!
Old Nov 2, 2005 | 03:00 PM
basecamp's Avatar
basecamp
I know that wire works as a ground that completes the circuit when you turn your key, it is possible that the little clip is touching metal somewhere it should not be or perhaps the wire is going to ground else where. If I remember correctly when you put your key in it pushes a metal pin up that touches the little clip and creates a ground, either this pin is really dirty and not returning to its down position or they is a short to ground somewhere in that wire. Hope this helps.
bigcountry1009
Nov 13, 2014 08:07 AM
cfd29
Jun 25, 2008 01:30 PM
fencer
Electrical Systems/Wiring
Apr 16, 2008 03:15 PM
rwhmax
1997 - 2003 F150
Dec 4, 2005 05:53 PM
drewg123
Sep 12, 2005 12:17 PM
