CPS ??????
Old Jul 24, 2010 | 08:03 AM
JRfore's Avatar
JRfore
CPS ??????
Ok I have 97 F-350, it would shut off going down the road Stop Re-Start no problem. I went to Ford got an new CPS (F7TZ-12K073-B) installed it went about 50 miles did the same thing as the old one. Could this be a bad sensor or could I have something else going on?
Old Jul 24, 2010 | 10:14 AM
thebig350's Avatar
thebig350
How about a little more info, my man. How many miles are on the rig? Any modifications to the stock set up? Time from last filter changes? Did it 'power down' when it died or just cut out completely? Any other problems you noticed leading up to this, or did it just start occouring out of the blue?
Old Jul 25, 2010 | 07:52 AM
JRfore's Avatar
JRfore
Sorry about that I haven’t posted much, it has Bully dog 6 position chip that I run in Stock all the time Except for a few week ago I turned it up one notch and ran it for about 5 miles and turned it back off (it was in the truck when I bought it and I was worried about the exhaust temps since It is stock) and no other Modification with 139000 miles on it, and about 1k on new filters. I have noticed the water in fuel light on for a short time a couple times before, but it goes right off. I have had the truck for about 4 years and it has shut of twice before and then I got the recall. Now with in the past 4 months it shut off about 4 times. No other warnings running down the road 60-65 shut off just like turning off the key. I put the new cps in on Friday night and Saturday morning went to get feed (roughly 50 miles) and it ran great all they way up and seemed to shift better than before on the way back it cut right off once it restarted and I got going it seemed to shift like it did before I changed the sensor. Other than that I did not notice any other changes.<O</O
Old Jul 25, 2010 | 07:22 PM
427 fordman's Avatar
427 fordman
It's definitely not unheard of maybe the cps is bad again. Some are faulty right out of the box. If I were you I'd try another one, you need a spare anyway.
Here is a better one you can try:
Ford part # F4TZ-12K073-C
IH part # 1876736C91
Old Jul 28, 2010 | 07:16 AM
JRfore's Avatar
JRfore
Thanks for the input, I will try the new part number and see what happens. I used the Truck last night, went about 30 miles pulling a 30 foot gooseneck with 200 bales of hay with no problems at all. I did notice once I stopped it sounded like it was surging a little at idle. It might have done before and I am just paying allot more attention to it now. fficeffice" /><O></O>
<O> </O>
<O> </O>
Old Jul 28, 2010 | 09:26 AM
jchosler's Avatar
jchosler
Which CPS does Ford put in during a recall? Is it the color I'm looking for?
My truck goes in this week for the recall
Old Jul 28, 2010 | 10:33 AM
Brown Falcon's Avatar
Brown Falcon
The recall will be the black CPS. Not known for lasting long.
I would use the black as a spare and get the dark grey one listed above by Darin.
Old Jul 28, 2010 | 10:53 AM
superduty4x4's Avatar
superduty4x4
Negatory. The recall will be either the gray or the new purplish one. Black was OEM.
Old Jul 28, 2010 | 12:03 PM
Brown Falcon
oops, maybe i'm bass ackwards...
Old Jul 28, 2010 | 12:29 PM
JRfore's Avatar
JRfore
The one I took out was Gray and the new one was Gray also.
Old Jul 28, 2010 | 01:55 PM
jchosler's Avatar
jchosler
The one I have now is just dandy so I might hold on to the new one for a spare
Old Jul 28, 2010 | 04:32 PM
427 fordman
The one they put in in the recall is light gray and the ones I listed above are dark gray.
Old Jul 28, 2010 | 06:24 PM
superduty4x4
Good luck, most dealers won't let you keep the old one.
strokin'_tatsch
228
Feb 7, 2026 07:00 AM
Leemakesmepee
28
Apr 12, 2014 09:23 PM
ftowelding
Dec 9, 2010 11:57 PM
guzzle92
183
May 10, 2007 03:12 PM
maevans
Nov 30, 2005 06:53 PM
