77 high boy electrical problems..wierd
Old Jul 22, 2010 | 12:24 AM
brad594's Avatar
brad594
When the lights are turned on, the right turn signal light on the dash comes on! Help please...any ideas?
Old Jul 22, 2010 | 01:18 AM
kendooley's Avatar
kendooley
Check your bulbs.
A taillight bulb with a broken filament touching the turn signal filament can backfeed voltage.
Old Jul 22, 2010 | 09:05 AM
704 dentside man's Avatar
704 dentside man
Feedback is a tell tale ground issue. Check your bulbs, sockets, plugs and ground wires. I usually go straight to the sockets though...9 times out of 10, they're the culprit for me. Even if they're not, the sockets are only $7-10, no biggie.
Old Jul 22, 2010 | 10:08 AM
Shooter00's Avatar
Shooter00
If the above suggestions don't help, pull the instrument cluster and double check that the signal bulb is actually coming on. I've seen them where the housing gets brittle and crumble, and light will bleed over into places it shouldn't. I replaced mine and the plastic allowed the signal light to illuminate the brake and fasten belts lenses. A little Krylon solved that.
Old Jul 22, 2010 | 10:38 AM
montana_highboy's Avatar
montana_highboy
Like mentioned above it's usually always GROUND GROUND GROUND! most likely at the bulbs socket.
Old Jul 22, 2010 | 12:21 PM
brad594's Avatar
brad594
Found it!!
It was the bulb! Thank God! This kind of stuff drives me nuts. I hate electrical problems. This was to easy for me, it normally would be a break in the main wire harness under the truck inside the frame through the cab along the inside of the bed. Thank you for all your QUICK responses!
ryank59701
Nov 28, 2015 10:19 PM
B-Rad31302
Nov 10, 2015 02:04 PM
James_24_85
Oct 28, 2014 02:28 PM
abe
Jul 30, 2014 07:56 PM
BigAl250
Jul 19, 2014 06:42 PM
