No running lights
Old Nov 9, 2015 | 10:57 PM
B-Rad31302's Avatar
B-Rad31302
No running lights
when i turn on the running lights or my headlights only one of the three lights turn on. the turn signal lights work normally with the signal but not with the headlights. i dont know if its in the wiring or a worn out switch.
Old Nov 9, 2015 | 11:04 PM
Dank Hill's Avatar
Dank Hill
Did this problem just occur? What Are these 3 lights, what year is the truck?
Old Nov 10, 2015 | 01:23 AM
B-Rad31302's Avatar
B-Rad31302
its a 92 and has done this since i bought it a year ago
Old Nov 10, 2015 | 01:54 AM
White 97 xlt's Avatar
White 97 xlt
I would start by checking the bulbs....
Old Nov 10, 2015 | 02:31 AM
B-Rad31302's Avatar
B-Rad31302
i checked the bulbs when i replaced the headlight lenses and they're both good and the signals work
Old Nov 10, 2015 | 12:55 PM
madpogue's Avatar
madpogue
The signals are a separate filament. Whether they work has no bearing on whether the parking lights work.
It's not the switch. All the parking lights / taillights are fed from the same set of contacts on the switch.
Did you check the small upper side marker light bulbs (IIRC they're 168/194 peanut bulbs)?
Do the taillights work?
Old Nov 10, 2015 | 02:04 PM
Diesel_Brad's Avatar
Diesel_Brad
Did you check and see if you have Power AND a ground to the running lights in question?
uknunn
Aug 6, 2017 01:09 PM
LX2UN
Jul 8, 2017 04:28 AM
rex2908406
Dec 6, 2011 12:22 PM
okwaho1650
Apr 12, 2009 07:28 PM
Meilichios
Electrical Systems/Wiring
Jan 19, 2004 08:52 AM
